Up to 20% off select tools
Philips Sonicare DiamondClean Spring Replacement
Views: 7K
View statistics:
Past 24 Hours:
6
Past 7 Days:
38
Past 30 Days:
186
All Time:
6,978
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • Spudger
    4.9
    1. Philips Sonicare DiamondClean Spring Replacement, Spring: step 1, image 1 of 1
      • Pull the toothbrush head off the toothbrush.
      Ask FixBot
    2. Philips Sonicare DiamondClean Spring Replacement: step 2, image 1 of 1
      • Use a spudger to pry the chrome cap from the base of the toothbrush.
      Ask FixBot
    3. Philips Sonicare DiamondClean Spring Replacement: step 3, image 1 of 3 Philips Sonicare DiamondClean Spring Replacement: step 3, image 2 of 3 Philips Sonicare DiamondClean Spring Replacement: step 3, image 3 of 3
      • Invert the toothbrush and apply pressure against the metal tip until the internals and casing separate.
      • Remove the internals from the casing.
      Ask FixBot
    4. Philips Sonicare DiamondClean Spring Replacement: step 4, image 1 of 1
      • Remove the rubbers covers from the circuit board and battery.
      Ask FixBot
    5. Philips Sonicare DiamondClean Spring Replacement: step 5, image 1 of 2 Philips Sonicare DiamondClean Spring Replacement: step 5, image 2 of 2
      • Separate the upper and lower components by sliding the circuit board section and motor section away from each other.
      • Remove the spring.
      Ask FixBot
2 other people completed this guide.
Author
with
Caleb Watson
515 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 38
Past 30 Days: 186
All Time: 6,978
