Philips Sonicare DiamondClean Circuit Board Replacement
  1. Philips Sonicare DiamondClean Circuit Board Replacement, Circuit Board: step 1, image 1 of 2 Philips Sonicare DiamondClean Circuit Board Replacement, Circuit Board: step 1, image 2 of 2
    • Pull the brush head from the toothbrush.
    Ask FixBot
  2. Philips Sonicare DiamondClean Circuit Board Replacement: step 2, image 1 of 1
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
    Ask FixBot
  3. Philips Sonicare DiamondClean Circuit Board Replacement: step 3, image 1 of 3 Philips Sonicare DiamondClean Circuit Board Replacement: step 3, image 2 of 3 Philips Sonicare DiamondClean Circuit Board Replacement: step 3, image 3 of 3
    • Invert the toothbrush and apply pressure against the metal tip until the internals and casing separate.
    • Remove the internals from the casing.
    Ask FixBot
  4. Philips Sonicare DiamondClean Circuit Board Replacement: step 4, image 1 of 1
    • Remove the rubber covers from the circuit board and battery.
    Ask FixBot
  5. Philips Sonicare DiamondClean Circuit Board Replacement: step 5, image 1 of 1
    • Carefully free the top end of the circuit board from the plastic clips holding it in place.
    Ask FixBot
  6. Philips Sonicare DiamondClean Circuit Board Replacement: step 6, image 1 of 1
    • Use the soldering iron to desolder the terminals marked F1, C5, R7, R6, and JP1.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices!
    • Remove the circuit board.
    Ask FixBot
2 other people completed this guide.
1 Guide Comment
If anyone needs to replace just the button, the part number is: Panasonic EVQ-PLHA15.
(you can also find variants with harder or softer click in the datasheet)
To desolder gently push a sharp point of tweezer or knife under the button, alternate melting the pins on one side while gently lifting, apply very light pressure and be careful not to lift the PCB pads.
Luke - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 79
All Time: 4,585
