Philips Somneo Motherboard Replacement
  1. Philips Somneo Motherboard Replacement, Antenna: step 1, image 1 of 1
    • Remove the four silicone feet on the bottom plate.
    • Remove the following Phillips screws from the bottom plate:
    • Two 9 mm screws
    • Two 13 mm screws
    Ask FixBot
  2. Philips Somneo Motherboard Replacement: step 2, image 1 of 2 Philips Somneo Motherboard Replacement: step 2, image 2 of 2
    • Remove the bottom plate from the device.
    Ask FixBot
  3. Philips Somneo Motherboard Replacement: step 3, image 1 of 2 Philips Somneo Motherboard Replacement: step 3, image 2 of 2
    • Disconnect the antenna connector by pulling it directly out of its port.
    • Remove the antenna.
    Ask FixBot
  4. Philips Somneo Motherboard Replacement, Motherboard: step 4, image 1 of 2 Philips Somneo Motherboard Replacement, Motherboard: step 4, image 2 of 2
    • Remove the four 9 mm Phillips screws securing the motherboard.
    Ask FixBot
  5. Philips Somneo Motherboard Replacement: step 5, image 1 of 2 Philips Somneo Motherboard Replacement: step 5, image 2 of 2
    • Gently pull the motherboard down until the cables are visible.
    • Take care not to strain the connected cables.
    Ask FixBot
  6. Philips Somneo Motherboard Replacement: step 6, image 1 of 3 Philips Somneo Motherboard Replacement: step 6, image 2 of 3 Philips Somneo Motherboard Replacement: step 6, image 3 of 3
    • Remove each cord by gently disconnecting each connector with your hand.
    Ask FixBot
  7. Philips Somneo Motherboard Replacement: step 7, image 1 of 3 Philips Somneo Motherboard Replacement: step 7, image 2 of 3 Philips Somneo Motherboard Replacement: step 7, image 3 of 3
    • Continue gently removing each cord with you hand.
    Ask FixBot
  8. Philips Somneo Motherboard Replacement: step 8, image 1 of 2 Philips Somneo Motherboard Replacement: step 8, image 2 of 2
    • Finish gently removing the final cord attached to the motherboard to successfully remove the motherboard.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Isaiah
332 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 29
All Time: 339
