Tools
Spudger4.9
Introduction
Go to step 1 ↓If your Philips Somneo light is faulty or not working, access the LED with this guide. For this guide, you will need a plastic opening tool/pick, a plastic and metal spudger, and a Phillips #00 screwdriver head. You will not need to do any difficult steps, but when removing the motherboard, be sure to disconnect the cables carefully.
Remove the four silicone feet on the bottom plate.
Remove the following Phillips screws from the bottom plate:
Two 9 mm screws
Two 13 mm screws
Use an opening pick to pry underneath the plastic covering the edges of the screen.
Place an opening tool in the space made between the screen and this plastic piece and pry up, working around the length of this circular piece to significantly loosen it.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
