Philips Somneo LCD Assembly Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
51
All Time:
329
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
If you need to reinstall a new LCD Housing unit then use this guide. For his guide, you will need mainly a Phillips #00 screwdriver head and any other tools that were used in the prerequisite guides such as a Spudger or iFixit Opening Tool. Will will not need to do any difficult steps but this guide will be time consuming.
Tools
    1. Philips Somneo LCD Assembly Replacement, Antenna: step 1, image 1 of 1
      • Remove the four silicone feet on the bottom plate.
      • Remove the following Phillips screws from the bottom plate:
      • Two 9 mm screws
      • Two 13 mm screws
      Ask FixBot
    2. Philips Somneo LCD Assembly Replacement: step 2, image 1 of 2 Philips Somneo LCD Assembly Replacement: step 2, image 2 of 2
      • Remove the bottom plate from the device.
      Ask FixBot
    3. Philips Somneo LCD Assembly Replacement: step 3, image 1 of 2 Philips Somneo LCD Assembly Replacement: step 3, image 2 of 2
      • Disconnect the antenna connector by pulling it directly out of its port.
      • Remove the antenna.
      Ask FixBot
    1. Philips Somneo LCD Assembly Replacement, Motherboard: step 4, image 1 of 2 Philips Somneo LCD Assembly Replacement, Motherboard: step 4, image 2 of 2
      • Remove the four 9 mm Phillips screws securing the motherboard.
      Ask FixBot
    2. Philips Somneo LCD Assembly Replacement: step 5, image 1 of 2 Philips Somneo LCD Assembly Replacement: step 5, image 2 of 2
      • Gently pull the motherboard down until the cables are visible.
      • Take care not to strain the connected cables.
      Ask FixBot
    3. Philips Somneo LCD Assembly Replacement: step 6, image 1 of 3 Philips Somneo LCD Assembly Replacement: step 6, image 2 of 3 Philips Somneo LCD Assembly Replacement: step 6, image 3 of 3
      • Remove each cord by gently disconnecting each connector with your hand.
      Ask FixBot
    4. Philips Somneo LCD Assembly Replacement: step 7, image 1 of 3 Philips Somneo LCD Assembly Replacement: step 7, image 2 of 3 Philips Somneo LCD Assembly Replacement: step 7, image 3 of 3
      • Continue gently removing each cord with you hand.
      Ask FixBot
    5. Philips Somneo LCD Assembly Replacement: step 8, image 1 of 2 Philips Somneo LCD Assembly Replacement: step 8, image 2 of 2
      • Finish gently removing the final cord attached to the motherboard to successfully remove the motherboard.
      Ask FixBot
    1. Philips Somneo LCD Assembly Replacement, LED Assembly: step 9, image 1 of 3 Philips Somneo LCD Assembly Replacement, LED Assembly: step 9, image 2 of 3 Philips Somneo LCD Assembly Replacement, LED Assembly: step 9, image 3 of 3
      • Use an opening pick to pry underneath the plastic covering the edges of the screen.
      • Place an opening tool in the space made between the screen and this plastic piece and pry up, working around the length of this circular piece to significantly loosen it.
      Ask FixBot
    2. Philips Somneo LCD Assembly Replacement: step 10, image 1 of 2 Philips Somneo LCD Assembly Replacement: step 10, image 2 of 2
      • The panel should be loosened significantly enough to be pulled off the main body, revealing the edges of the screen.
      Ask FixBot
    3. Philips Somneo LCD Assembly Replacement: step 11, image 1 of 2 Philips Somneo LCD Assembly Replacement: step 11, image 2 of 2
      • Remove the two 13 mm Phillips #0 screws on the bottom edges of the screen.
      • Remove the 9 mm Phillips #0 screws on the upper edge of the screen.
      Ask FixBot
    4. Philips Somneo LCD Assembly Replacement: step 12, image 1 of 3 Philips Somneo LCD Assembly Replacement: step 12, image 2 of 3 Philips Somneo LCD Assembly Replacement: step 12, image 3 of 3
      • Remove the display assembly.
      Ask FixBot
    5. Philips Somneo LCD Assembly Replacement: step 13, image 1 of 3 Philips Somneo LCD Assembly Replacement: step 13, image 2 of 3 Philips Somneo LCD Assembly Replacement: step 13, image 3 of 3
      • On the back of the screen, remove the four 9 mm Phillips #00 screws, disconnecting the LED assembly.
      Ask FixBot
    6. Philips Somneo LCD Assembly Replacement: step 14, image 1 of 3 Philips Somneo LCD Assembly Replacement: step 14, image 2 of 3 Philips Somneo LCD Assembly Replacement: step 14, image 3 of 3
      • Two cables connected to the LED were once connected to the motherboard, but are still attached to the body. They are threaded through black ovals connected to the body by a hard black adhesive.
      • Using a metal spudger, scrape underneath this adhesive and pry up, freeing the cable from the body. Repeat this for the other cable to free the LED.
      Ask FixBot
    1. Philips Somneo LCD Assembly Replacement, LCD Assembly: step 15, image 1 of 1
      • Remove the two 13 mm Phillips screws securing the LCD assembly.
      Ask FixBot
    2. Philips Somneo LCD Assembly Replacement: step 16, image 1 of 2 Philips Somneo LCD Assembly Replacement: step 16, image 2 of 2
      • Remove the LCD assembly.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Isaiah
332 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 51
All Time: 329
