Philips Satinelle On/Off Switch Replacement
    1. Philips Satinelle On/Off Switch Replacement, Plastic Cover: step 1, image 1 of 3 Philips Satinelle On/Off Switch Replacement, Plastic Cover: step 1, image 2 of 3 Philips Satinelle On/Off Switch Replacement, Plastic Cover: step 1, image 3 of 3
      • Remove the head by pushing it to the right.
      Ask FixBot
    2. Philips Satinelle On/Off Switch Replacement: step 2, image 1 of 2 Philips Satinelle On/Off Switch Replacement: step 2, image 2 of 2
      • Use a metal spudger to pry open the casing.
      • Caution: The epilator's internal components could be damaged if you shove the spudger in too far.
      Ask FixBot
    3. Philips Satinelle On/Off Switch Replacement: step 3, image 1 of 1
      • Pull the plastic casing apart with your hands.
      • The plastic tab connecting the cover is likely going to break when you pull the device apart. This will not affect the operation of the epilator.
      Ask FixBot
    1. Philips Satinelle On/Off Switch Replacement, On/Off Switch: step 4, image 1 of 1
      • Remove the green board and the black socket.
      Ask FixBot
    2. Philips Satinelle On/Off Switch Replacement: step 5, image 1 of 1
      • Slide the switch down toward the socket.
      Ask FixBot
    3. Philips Satinelle On/Off Switch Replacement: step 6, image 1 of 3 Philips Satinelle On/Off Switch Replacement: step 6, image 2 of 3 Philips Satinelle On/Off Switch Replacement: step 6, image 3 of 3
      • Put the components back into the frame
      • If the switch won't line up with the plastic square, make sure the large switch on the front of the operator is in the "off" position.
      Ask FixBot
Riannon Varney
168 Reputation
1 Guide authored
Marist, Team S1-G1, Chaterdon Fall 2018 Member of Marist, Team S1-G1, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G1
3 Members
48 Guides authored
1 Guide Comment
Very precise instructions, thanks!
carlos - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 77
All Time: 2,366
