Philips Satinelle Motor Replacement
    1. Philips Satinelle Motor Replacement, Plastic Cover: step 1, image 1 of 3 Philips Satinelle Motor Replacement, Plastic Cover: step 1, image 2 of 3 Philips Satinelle Motor Replacement, Plastic Cover: step 1, image 3 of 3
      • Remove the head by pushing it to the right.
      Ask FixBot
    2. Philips Satinelle Motor Replacement: step 2, image 1 of 2 Philips Satinelle Motor Replacement: step 2, image 2 of 2
      • Use a metal spudger to pry open the casing.
      • Caution: The epilator's internal components could be damaged if you shove the spudger in too far.
      Ask FixBot
    3. Philips Satinelle Motor Replacement: step 3, image 1 of 1
      • Pull the plastic casing apart with your hands.
      • The plastic tab connecting the cover is likely going to break when you pull the device apart. This will not affect the operation of the epilator.
      Ask FixBot
    1. Philips Satinelle Motor Replacement, Motor: step 4, image 1 of 2 Philips Satinelle Motor Replacement, Motor: step 4, image 2 of 2
      • Remove the components.
      Ask FixBot
    2. Philips Satinelle Motor Replacement: step 5, image 1 of 3 Philips Satinelle Motor Replacement: step 5, image 2 of 3 Philips Satinelle Motor Replacement: step 5, image 3 of 3
      • Hold the motor with the gears face away from you.
      • Gently push the motor out with your thumbs.
      Ask FixBot
2 other people completed this guide.
Madeline Casalino
325 Reputation
3 Guides authored
Marist, Team S1-G1, Chaterdon Fall 2018 Member of Marist, Team S1-G1, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G1
3 Members
48 Guides authored
2 Guide Comments
i dont know what i am doing wrong but it is not openning
Aj Queen - Reply Share
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 68
All Time: 3,012
