Philips Satinelle Gear Replacement
    1. Philips Satinelle Gear Replacement, Philips Satinelle Disassembly: step 1, image 1 of 2 Philips Satinelle Gear Replacement, Philips Satinelle Disassembly: step 1, image 2 of 2
      • Unplug the device and remove the purple guard.
      • Remove the head by pressing the right side of the head (with the device facing away from you).
      • You will hear a 'click' and the head will become dislodged from the body of the device.
      Ask FixBot
    2. Philips Satinelle Gear Replacement: step 2, image 1 of 3 Philips Satinelle Gear Replacement: step 2, image 2 of 3 Philips Satinelle Gear Replacement: step 2, image 3 of 3
      • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
      • Be careful not to lose the clip. It will likely fly off when it releases.
      Ask FixBot
    3. Philips Satinelle Gear Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • The left side will swing down.
      • Remove the Tweezers.
      Ask FixBot
    4. Philips Satinelle Gear Replacement: step 4, image 1 of 3 Philips Satinelle Gear Replacement: step 4, image 2 of 3 Philips Satinelle Gear Replacement: step 4, image 3 of 3
      • Remove the plastic component that swings down.
      • Use fingernails to lift clips from stubs.
      Ask FixBot
    5. Philips Satinelle Gear Replacement: step 5, image 1 of 3 Philips Satinelle Gear Replacement: step 5, image 2 of 3 Philips Satinelle Gear Replacement: step 5, image 3 of 3
      • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
      Ask FixBot
    6. Philips Satinelle Gear Replacement: step 6, image 1 of 3 Philips Satinelle Gear Replacement: step 6, image 2 of 3 Philips Satinelle Gear Replacement: step 6, image 3 of 3
      • Use a spudger to pry the gear housing unit from the base.
      Ask FixBot
    7. Philips Satinelle Gear Replacement: step 7, image 1 of 3 Philips Satinelle Gear Replacement: step 7, image 2 of 3 Philips Satinelle Gear Replacement: step 7, image 3 of 3
      • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
      Ask FixBot
    1. Philips Satinelle Gear Replacement, Gear Replacement: step 8, image 1 of 1
      • Replace the gear and re-insert the pin.
      • Ensure that pin is protruding slightly, it should not be flush.
      Ask FixBot
Nathan Christian
505 Reputation
3 Guides authored
IUPUI, Team S5-G5, Wilson Fall 2017 Member of IUPUI, Team S5-G5, Wilson Fall 2017
IUPUI-WILSON-F17S5G5
3 Members
48 Guides authored
3 Guide Comments
What size pinion is used in it? Kindly help.
Wilkis James - Reply Share
Can you send link to buy this piece?
Or 3d Printer file?
Thanks
Emilio Hernandez - Reply Share
Tienes las medidas de los engranajes
luis vega - Reply Share
Past 24 Hours: 0
Past 7 Days: 22
Past 30 Days: 125
All Time: 2,832
