Philips SBA1060 Circuit Board Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
88
All Time:
1,839
Comments: 2
2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
The circuit board is the large, flat, green rectangle in the middle of the device. This guide will detail the steps in how to replace the circuit board.
Tools
    1. Philips SBA1060 Circuit Board Replacement, Battery Casing: step 1, image 1 of 1
      • Remove the back cover by sliding it off.
      • Remove the 3 AAA batteries.
      Ask FixBot
    2. Philips SBA1060 Circuit Board Replacement: step 2, image 1 of 3 Philips SBA1060 Circuit Board Replacement: step 2, image 2 of 3 Philips SBA1060 Circuit Board Replacement: step 2, image 3 of 3
      • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
      • A larger screwdriver head and more force may be required for damaged screws.
      • Remove the triangular end piece by pulling it straight off.
      Ask FixBot
    3. Philips SBA1060 Circuit Board Replacement: step 3, image 1 of 2 Philips SBA1060 Circuit Board Replacement: step 3, image 2 of 2
      • Remove the colored grill by sliding it off in the direction of the removed end piece.
      • Pry off the back battery panel with the plastic opening tool.
      • Be careful to avoid tearing any wires.
      Ask FixBot
    1. Philips SBA1060 Circuit Board Replacement, Circuit Board: step 4, image 1 of 1
      • Remove the two screws on opposite ends of the circuit board with the PH0 size philips head screw driver.
      • Remove the damaged circuit board from the device.
      Ask FixBot
    2. Philips SBA1060 Circuit Board Replacement: step 5, image 1 of 2 Philips SBA1060 Circuit Board Replacement: step 5, image 2 of 2
      • Remove the battery plug from the circuit board by pulling out the plugs to fully remove back panel.
      • Remove the speaker plugs from the circuit board by pulling out the plugs. They are located on opposite sides of the circuit board.
      • NOTE: When reassembling, note that the speaker with the red wire goes to the red plug, and the speaker with the white wire goes to the adjacent white plug.
      • Remove the light plug from the circuit board.
      • NOTE: This plug is twice as wide as the speaker and battery plugs.
      • Reassemble the device.
      Ask FixBot
2 other people completed this guide.
April Driscoll
321 Reputation
3 Guides authored
Clemson, Team 14-4, Benson Fall 2013 Member of Clemson, Team 14-4, Benson Fall 2013
CLEM-BENSON-F13S14G4
3 Members
48 Guides authored
2 Guide Comments
Is that one of those cheap pam amps that run from 5v?
fabio souza jr - Reply Share
Nice picture,it helps a lot in trouble shooting !
sergio - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 88
All Time: 1,839
