Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Philips Roller Controller Repair
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
90
All Time:
498
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Community-Contributed Guide
    1. Philips Roller Controller Repair, Philips Roller Controller Repair: step 1, image 1 of 1
      • Remove the 5 screws on the bottom edge.
      Ask FixBot
    2. Philips Roller Controller Repair: step 2, image 1 of 1
      • Detach the top cover.
      • Watch out for the connector for the buttons on the right side. Disconnect it.
      Ask FixBot
    3. Philips Roller Controller Repair: step 3, image 1 of 1
      • Disconnect the two connectors. Note their position for reassembly.
      Ask FixBot
    4. Philips Roller Controller Repair: step 4, image 1 of 3 Philips Roller Controller Repair: step 4, image 2 of 3 Philips Roller Controller Repair: step 4, image 3 of 3
      • You can pull the tabs on both sides slightly outward and then carefully pull the clip upward.
      • Use a pick to carefully release the bearing retainer.
      Ask FixBot
    5. Philips Roller Controller Repair: step 5, image 1 of 1
      • Remove the two screws and you can take out the PCB.
      Ask FixBot
    6. Philips Roller Controller Repair: step 6, image 1 of 1
      • Replacement parts you need:
      • 4x LTR-301 Infrared Receiver
      • 4x LTE-302 Infrared Emitter
      • The emitters, LTE-302, are mounted on the inside and replace the BLUE-tinted emitters.
      • The receivers are positioned against the outer edge of the board. These are the LTR-301 types.
      • Often only the emitters are faulty, but we prefer to replace both the emitters and the receivers.
      Ask FixBot
    7. Philips Roller Controller Repair: step 7, image 1 of 2 Philips Roller Controller Repair: step 7, image 2 of 2
      • Desolder the emitters.
      • Place the replacement parts and solder them back into place with a little flux.
      • Ensure that you place the parts neatly into the holder and that both the receiver and the transmitter are at the same height.
      Ask FixBot
      • You can reassemble the controller in reverse order.
      Ask FixBot
Author
with
willy
277 Reputation
2 Guides authored
HomeComputerMuseum Member of HomeComputerMuseum
Community
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 90
All Time: 498
