Philips Respironics V60 Touchscreen Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Philips Respironics V60 Touchscreen Replacement, Touchscreen: step 1, image 1 of 1
    • From the Diagnostics Menu, select Touch Screen Calibration. The Calibrate Touch Screen screen is displayed.
    • Follow the steps shown. Press on the middle of each target with a blunt, narrow object.
    • NOTE: If the Touch Screen Calibration button does not respond, press the Accept button on the navigation ring to begin
    • If the calibration is not successful, have the ventilator serviced.
    Ask FixBot
  2. Philips Respironics V60 Touchscreen Replacement: step 2, image 1 of 1
    • Press and release the ON/Shutdown key, opening the Shutdown window in the screen.
    • Select Ventilator Shutdown, which will shut down the ventilator.
    • Improper shutdown may cause a Power has been restored message the next time the ventilator is turned on.
    Ask FixBot
  3. Philips Respironics V60 Touchscreen Replacement: step 3, image 1 of 1
    • Remove the screws from the end cap and remove the end cap.
    • Remove the screws from the rear bezel.
    • Separate the front and rear bezel.
    Ask FixBot
  4. Philips Respironics V60 Touchscreen Replacement: step 4, image 1 of 1
    • Disconnect these cables from the UI PCBA: • Switch PCBA cable • Nav-ring cable • Power switch overlay cable • Touch screen cable
    • Remove the switch PCBA.
    • Remove the screw that attaches the cable clamp to the LCD tray.
    • Remove the screws and washers that attach the LCD tray to the front bezel, then remove the LCD tray.
    • Remove the touch screen from the front bezel.
    Ask FixBot
Weihan Du
241 Reputation
2 Guides authored
Cal Poly, Team S7-G10, Paton Spring 2020 Member of Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 37
All Time: 2,790
