Up to 20% off select tools
Philips PD9000 37 Buttons Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
108
All Time:
2,535
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
Introduction
Go to step 1 ↓
Buttons on your portable DVD player can become damaged and no longer able to respond, this guide will direct you on how to replace the button panel. You will be able to complete this task with a minimum amount of time and tools required.
    1. Philips PD9000 37 Buttons Replacement, Buttons: step 1, image 1 of 1
      • Lay the player flat so the outside casing is facing upwards. Using the screwdriver, unscrew all the case screws on the bottom of the player.
      Ask FixBot
    2. Philips PD9000 37 Buttons Replacement: step 2, image 1 of 3 Philips PD9000 37 Buttons Replacement: step 2, image 2 of 3 Philips PD9000 37 Buttons Replacement: step 2, image 3 of 3
      • Open the disc flap and unscrew the screws inside. There will be three screws.
      • Using spudger, pry open the disk casing, and pull upwards removing it from the outer casing.
      Ask FixBot
    3. Philips PD9000 37 Buttons Replacement: step 3, image 1 of 3 Philips PD9000 37 Buttons Replacement: step 3, image 2 of 3 Philips PD9000 37 Buttons Replacement: step 3, image 3 of 3
      • After casing has been detached, there will be a wire connecting the button panel on the disk flap case to the motherboard.
      • To detach this wire, use your fingers and tightly pinch the plastic connector, and gently pull upwards disconnecting it from the motherboard.
      Ask FixBot
    4. Philips PD9000 37 Buttons Replacement: step 4, image 1 of 1
      • On the bottom side of the disk flap case, the back of the button panel will be visible. Using a Philips J0 screwdriver, unscrew all 6 screws.
      Ask FixBot
    5. Philips PD9000 37 Buttons Replacement: step 5, image 1 of 3 Philips PD9000 37 Buttons Replacement: step 5, image 2 of 3 Philips PD9000 37 Buttons Replacement: step 5, image 3 of 3
      • Once unscrewed. gently pull upwards detaching the button panel from the casing.
      Ask FixBot
Author
with
Abigail Scarborough
193 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 108
All Time: 2,535
