Philips PD9000 37 Battery Replacement
    1. Philips PD9000 37 Battery Replacement, White Outer Housing: step 1, image 1 of 3 Philips PD9000 37 Battery Replacement, White Outer Housing: step 1, image 2 of 3 Philips PD9000 37 Battery Replacement, White Outer Housing: step 1, image 3 of 3
      • Lay the player flat so the bottom outside is showing. Using the Phillips #0 screwdriver, unscrew all the housing screws on the bottom of the player.
      • Have the player sitting upright, remove the rubber stoppers in order to get to the screw. Unscrew the inside screws by the screen using the Philips #0 screwdriver.
      • Remove the rubber stoppers for the bottom two screws as well. Unscrew the middle two screws.
      Ask FixBot
    2. Philips PD9000 37 Battery Replacement: step 2, image 1 of 2 Philips PD9000 37 Battery Replacement: step 2, image 2 of 2
      • Open the disc flap and remove the screws inside with the Phillips #0 screwdriver. There will be three screws.
      Ask FixBot
    3. Philips PD9000 37 Battery Replacement: step 3, image 1 of 3 Philips PD9000 37 Battery Replacement: step 3, image 2 of 3 Philips PD9000 37 Battery Replacement: step 3, image 3 of 3
      • Start removing the inside black face plate of the player by using a prying method between the white outer housing and the black face plate with a metal spudger.
      • Pull the black face plate off once you have pried it from the white housing. The bottom inside layer should pop off.
      • Using the same prying method with the metal spudger, start prying off the screens white outer housing.
      Ask FixBot
    4. Philips PD9000 37 Battery Replacement: step 4, image 1 of 3 Philips PD9000 37 Battery Replacement: step 4, image 2 of 3 Philips PD9000 37 Battery Replacement: step 4, image 3 of 3
      • The light panel on the front can just pop right off.
      • To remove the metal bar against the battery, unscrew the screws with the phillips #0 screwdriver.
      • After unscrewing you can just lift the metal bar off.
      Ask FixBot
    1. Philips PD9000 37 Battery Replacement, Battery: step 5, image 1 of 2 Philips PD9000 37 Battery Replacement, Battery: step 5, image 2 of 2
      • Take the metal rounded rectangle spudger and place under battery edge.
      • Avoid breaking plastic cover.
      • press down hard on held end of spudger, you will hear the battery un-stick.
      Ask FixBot
    2. Philips PD9000 37 Battery Replacement: step 6, image 1 of 2 Philips PD9000 37 Battery Replacement: step 6, image 2 of 2
      • Use a soldering iron to melt the metal connecting the battery wires to the mother board.
      • Quickly remove each wire after melting the metal
      • Soldering iron is HOT and will burn you.
      • Wires will get HOT and may burn you.
      Ask FixBot
    3. Philips PD9000 37 Battery Replacement: step 7, image 1 of 1
      • Properly dispose of battery as soon as possible
      • If battery is not disposed of, it may bloat and explode
      • If battery leaks, dispose of right away and wash hands.
      Ask FixBot
5 other people completed this guide.
Kendal Cler
969 Reputation
6 Guides authored
3 Guide Comments
Where can this battery be bought? After a year using, playing time is down to 3 hours
L.Johnson - Reply Share
Yeah. Where can I get the battery?
Bryan Allen - Reply Share
This tutorial is completely worthless if one doesn't have a battery to replace the one removed. Now two people have asked where to get a replacement yet you have not responded. Undoubtedly countless others have come by looking for a suitable replacement and saw that there was no response and no solution. Congratulations on helping no one. It would seem you're nothing more than a blowhard, a big show off, “Oh look at me I am fixing my bad battery. Aren't you impressed?” I'm not.
kurt - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 49
All Time: 8,651
