Philips Norelco MultiGroom 3100 Casing Replacement
  1. Philips Norelco MultiGroom 3100 Casing Replacement, Power Button: step 1, image 1 of 1
    • Remove the comb from the top of the trimmer.
    Ask FixBot
  2. Philips Norelco MultiGroom 3100 Casing Replacement: step 2, image 1 of 2 Philips Norelco MultiGroom 3100 Casing Replacement: step 2, image 2 of 2
    • Grip the attachment and twist it counterclockwise until you hear a click.
    • Pull the attachment up to remove it from the trimmer.
    Ask FixBot
  3. Philips Norelco MultiGroom 3100 Casing Replacement: step 3, image 1 of 2 Philips Norelco MultiGroom 3100 Casing Replacement: step 3, image 2 of 2
    • Hold the trimmer upright so it is facing you.
    • Insert the plastic opening tool in the gap at the top of the power button.
    Ask FixBot
  4. Philips Norelco MultiGroom 3100 Casing Replacement: step 4, image 1 of 1
    • Apply pressure to pry off the power button.
    Ask FixBot
  5. Philips Norelco MultiGroom 3100 Casing Replacement, Casing: step 5, image 1 of 2 Philips Norelco MultiGroom 3100 Casing Replacement, Casing: step 5, image 2 of 2
    • Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
    • Separate the bezel one clip at a time so that the clips do not break.
    Ask FixBot
  6. Philips Norelco MultiGroom 3100 Casing Replacement: step 6, image 1 of 2 Philips Norelco MultiGroom 3100 Casing Replacement: step 6, image 2 of 2
    • Insert the spudger in the indicated hole and apply a tilting force to loosen the outer casing.
    • Pull upward on the top of the inner housing to remove it from the outer casing.
    Ask FixBot
13 other people completed this guide.
ahaharevolution
909 Reputation
3 Guides authored
USF Tampa, Team 1-1, Leahy Fall 2015 Member of USF Tampa, Team 1-1, Leahy Fall 2015
USFT-LEAHY-F15S1G1
2 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 76
All Time: 5,838
