Philips HD9252 Transformer Replacement
    1. Philips HD9252 Transformer Replacement, Top: step 1, image 1 of 1
      • Insert a nylon spudger underneath the top of the device.
      • Leverage the tool and pop off each of the eight tabs holding the plastic cover in place.
      Ask FixBot
    2. Philips HD9252 Transformer Replacement: step 2, image 1 of 1
      • Remove the four 12.4 mm screws in each of the corners using a JIS #1 screwdriver.
      Ask FixBot
    3. Philips HD9252 Transformer Replacement: step 3, image 1 of 1
      • Remove the top by lifting it upwards and setting it down.
      Ask FixBot
    1. Philips HD9252 Transformer Replacement, Transformer: step 4, image 1 of 1
      • Remove the two 39.5 mm screws attached to the black piece of the transformer using a JIS #1 screwdriver.
      Ask FixBot
    2. Philips HD9252 Transformer Replacement: step 5, image 1 of 1
      • Remove the top piece, using a Phillips #2 screwdriver, to get the whole transformer.
      Ask FixBot
    3. Philips HD9252 Transformer Replacement: step 6, image 1 of 2 Philips HD9252 Transformer Replacement: step 6, image 2 of 2
      • Remove the brown and white wire attached to the transformer using a spudger.
      • Disconnect both the brown and white cables.
      Ask FixBot
    4. Philips HD9252 Transformer Replacement: step 7, image 1 of 1
      • Replace the transformer.
      Ask FixBot
1 Guide Comment
This is not the transformer, it is the coil of the shaded-pole motor.
Werner Hinzmann - Reply Share
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 63
All Time: 1,720
