Up to 20% off select tools
Philips HD9252 Top Replacement
Views: 7K
View statistics:
Past 24 Hours:
15
Past 7 Days:
139
Past 30 Days:
623
All Time:
7,024
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 minutes
Difficulty: Moderate
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Use this guide to disassemble the Philips HD9252 air fryer top, manufactured by Philips. Once this is removed, the main components of the device will be accessible, such as the timer and touch screen.
    1. Philips HD9252 Top Replacement, Top: step 1, image 1 of 1
      • Insert a nylon spudger underneath the top of the device.
      • Leverage the tool and pop off each of the eight tabs holding the plastic cover in place.
      Ask FixBot
    2. Philips HD9252 Top Replacement: step 2, image 1 of 1
      • Remove the four 12.4 mm screws in each of the corners using a JIS #1 screwdriver.
      Ask FixBot
    3. Philips HD9252 Top Replacement: step 3, image 1 of 1
      • Remove the top by lifting it upwards and setting it down.
      Ask FixBot
7 other people completed this guide.
Author
with
Zach Person
685 Reputation
4 Guides authored
1 Guide Comment
thanks, now need to figure out how to repair the thin drawer switch plastic gig broken flush at the exit!
Stephane.Plaisance@telenet.be - Reply Share
Past 24 Hours: 15
Past 7 Days: 139
Past 30 Days: 623
All Time: 7,024
