Shop the Holiday Gift Guide
Philips DVP642 Power Supply Replacement
Views: 15K
View statistics:
Past 24 Hours:
6
Past 7 Days:
34
Past 30 Days:
106
All Time:
14,799
Comments: 1
1 comment on steps.
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will walk you through removing the old power supply for the DVD player so that a new one may be installed. This guide will also show you how to replace a blown fuse if needed.
Tools
    1. Philips DVP642 Power Supply Replacement, Top Panel: step 1, image 1 of 2 Philips DVP642 Power Supply Replacement, Top Panel: step 1, image 2 of 2
      • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
      • Remove five 7.5 mm Phillips screws on the back of the player.
      Ask FixBot
    2. Philips DVP642 Power Supply Replacement: step 2, image 1 of 2 Philips DVP642 Power Supply Replacement: step 2, image 2 of 2
      • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
      Ask FixBot
    1. Philips DVP642 Power Supply Replacement, Power Supply: step 3, image 1 of 2 Philips DVP642 Power Supply Replacement, Power Supply: step 3, image 2 of 2
      • Slide the power cord out from the case.
      • Be sure not to lose the rubber clip that is wrapped around the cord.
      Ask FixBot
    2. Philips DVP642 Power Supply Replacement: step 4, image 1 of 1
      • Remove the ribbon attached to the power supply by pushing the latch and gently pulling up.
      Ask FixBot
    3. Philips DVP642 Power Supply Replacement: step 5, image 1 of 2 Philips DVP642 Power Supply Replacement: step 5, image 2 of 2
      • Now remove this ribbon wire by grasping the white head firmly and pulling up gently.
      Ask FixBot
    4. Philips DVP642 Power Supply Replacement: step 6, image 1 of 2 Philips DVP642 Power Supply Replacement: step 6, image 2 of 2
      • Remove these two 7.5m Phillips screws and the matching set at the other end of the supply.
      • Now remove the ribbon that attaches the power supply to the motherboard by grasping the white head and gently pulling up.
      Ask FixBot
    5. Philips DVP642 Power Supply Replacement: step 7, image 1 of 3 Philips DVP642 Power Supply Replacement: step 7, image 2 of 3 Philips DVP642 Power Supply Replacement: step 7, image 3 of 3
      • Remove the last screw.
      • Pinch this plastic prong and slide the power supply up and over it. The power supply should lift free.
      Ask FixBot
    6. Philips DVP642 Power Supply Replacement: step 8, image 1 of 2 Philips DVP642 Power Supply Replacement: step 8, image 2 of 2
      • Your power supply is now free!
      • If the fuse circled here is blown (the small wire in the glass tube is missing or broken), remove it by pinching it tightly and pulling it straight out.
      • You can find a new fuse here.
      Ask FixBot
7 other people completed this guide.
Author
with
Toby Goldsteinholm
372 Reputation
2 Guides authored
Cal Poly, Team 21-20, Maness Fall 2011 Member of Cal Poly, Team 21-20, Maness Fall 2011
CPSU-MANESS-F11S21G20
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 34
Past 30 Days: 106
All Time: 14,799
