Philips DVP642 Motherboard Replacement
Views: 13K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
102
All Time:
12,739
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
In this guide you will locate screws and ribbon wires holding the motherboard in the player. After removal the motherboard itself can be repaired on the component level.
Tools
    1. Philips DVP642 Motherboard Replacement, Top Panel: step 1, image 1 of 2 Philips DVP642 Motherboard Replacement, Top Panel: step 1, image 2 of 2
      • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
      • Remove five 7.5 mm Phillips screws on the back of the player.
      Ask FixBot
    2. Philips DVP642 Motherboard Replacement: step 2, image 1 of 2 Philips DVP642 Motherboard Replacement: step 2, image 2 of 2
      • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
      Ask FixBot
    1. Philips DVP642 Motherboard Replacement, Motherboard: step 3, image 1 of 3 Philips DVP642 Motherboard Replacement, Motherboard: step 3, image 2 of 3 Philips DVP642 Motherboard Replacement, Motherboard: step 3, image 3 of 3
      • Locate the first three ribbon wires.
      • Remove the ribbon wires by grasping firmly as near to the plastic head as possible and pulling.
      • Be firm, but gentle when pulling to avoid pulling the wires off the head.
      Ask FixBot
    2. Philips DVP642 Motherboard Replacement: step 4, image 1 of 3 Philips DVP642 Motherboard Replacement: step 4, image 2 of 3 Philips DVP642 Motherboard Replacement: step 4, image 3 of 3
      • Remove the fourth ribbon wire as in step 2.
      • Remove the fifth ribbon wire by grasping both sides of the black clip and pulling up. When reinserting, pull black clip up, insert the ribbon wire, and push the black clip back down.
      Ask FixBot
    3. Philips DVP642 Motherboard Replacement: step 5, image 1 of 2 Philips DVP642 Motherboard Replacement: step 5, image 2 of 2
      • Remove the following screws:
      • 7.5 mm Phillips screws (2) that secure the motherboard to the bottom panel. The screw on the top right will also be attached to a grounding wire, it is okay to remove this screw.
      • Remove the 7.5 mm Phillips screw on the bottom right that attaches the grounding wire to the disc tray.
      • 7.5 mm Phillips screws (4) on outside of player near input/output plugs.
      Ask FixBot
    4. Philips DVP642 Motherboard Replacement: step 6, image 1 of 1
      • Remove the motherboard by pulling it back and then up gently.
      • The input/output plugs should slide out easily from the holes in the back panel.
      Ask FixBot
6 other people completed this guide.
Nathan Klammer
521 Reputation
3 Guides authored
Cal Poly, Team 21-20, Maness Fall 2011 Member of Cal Poly, Team 21-20, Maness Fall 2011
CPSU-MANESS-F11S21G20
4 Members
60 Guides authored
1 Guide Comment
Dvp3005/Ik mother bord .how much price
Md Younus - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 102
All Time: 12,739
