Philips DVP5992-F7 USB port Replacement
  1. Philips DVP5992-F7 USB port Replacement, USB port: step 1, image 1 of 3 Philips DVP5992-F7 USB port Replacement, USB port: step 1, image 2 of 3 Philips DVP5992-F7 USB port Replacement, USB port: step 1, image 3 of 3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
    Ask FixBot
  2. Philips DVP5992-F7 USB port Replacement: step 2, image 1 of 2 Philips DVP5992-F7 USB port Replacement: step 2, image 2 of 2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
    Ask FixBot
  3. Philips DVP5992-F7 USB port Replacement: step 3, image 1 of 3 Philips DVP5992-F7 USB port Replacement: step 3, image 2 of 3 Philips DVP5992-F7 USB port Replacement: step 3, image 3 of 3
    • Locate the bundled cable connectors that attaches the USB port to the motherboard.
    • Firmly grasp the bundled cable connector and lift it from the motherboard.
    Ask FixBot
  4. Philips DVP5992-F7 USB port Replacement: step 4, image 1 of 2 Philips DVP5992-F7 USB port Replacement: step 4, image 2 of 2
    • Locate the area behind the USB port within the interior of the DVD Player.
    • Unscrew the two 6.35 mm Phillips #1 screws located behind the USB port.
    Ask FixBot
  5. Philips DVP5992-F7 USB port Replacement: step 5, image 1 of 2 Philips DVP5992-F7 USB port Replacement: step 5, image 2 of 2
    • Use the plastic opening tool to press down on the brass clip that holds the USB port in place.
    • Pull back the USB Port to remove it from the DVD player.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 36
All Time: 964
