Philips DS3000 Speakers Replacement
  1. Philips DS3000 Speakers Replacement, Speakers: step 1, image 1 of 1
    Tool used on this step:
    iFixit Opening Tool
    $1.99
    Buy
    • Insert an opening tool between the gray front casing and white back casing.
    • Pry the gray casing away from the white casing.
    Ask FixBot
  2. Philips DS3000 Speakers Replacement: step 2, image 1 of 1
    • Lift the metal latch on the ZIF connector using a spudger.
    • Gently pull the ribbon away from the connector.
    • If you are unfamiliar with using connectors, consult this guide.
    • Ensure the connector’s latch is fully lifted before pulling the ribbon cable. This will prevent cable damage.
    Ask FixBot
  3. Philips DS3000 Speakers Replacement: step 3, image 1 of 1
    Phillips #1 Screwdriver
    $5.49
    Buy
    Ask FixBot
  4. Philips DS3000 Speakers Replacement: step 4, image 1 of 1
    iFixit Opening Tool
    $1.99
    Buy
    • Slowly pry around the black internal housing using an opening tool.
    • Pull the loosened black lid away from the back housing.
    Ask FixBot
  5. Philips DS3000 Speakers Replacement: step 5, image 1 of 1
    $5.49
    Buy
    • Locate the green circuit board on the back of the black lid.
    • Remove the four 8 mm Phillips #1 screws securing the circuit board using a Phillips #1 Screwdriver. The screws are located at the four corners of the board.
    Ask FixBot
  6. Philips DS3000 Speakers Replacement: step 6, image 1 of 1
    $5.49
    Buy
    • Remove the single 8 mm Phillips #1 screw using a Phillips #1 Screwdriver.
    • Pull the speaker port (the large black tube) off the main black housing.
    Ask FixBot
  7. Philips DS3000 Speakers Replacement: step 7, image 1 of 1
    $5.49
    Buy
    • Remove the four 7 mm Phillips #1 screws holding the speaker in place using a Phillips #1 Screwdriver.
    • The speaker is located under the speaker port, which you removed in Step 6.
    Ask FixBot
  8. Philips DS3000 Speakers Replacement: step 8, image 1 of 1
    • Gently pull the speaker away from the black housing.
    • The speaker should remain connected to the housing through a pair of wires.
    Ask FixBot
  9. Philips DS3000 Speakers Replacement: step 9, image 1 of 1
    • Carefully score an inch of the black sponge insulation with a wire cutter.
    • Gently pull the foam away from the wires.
    • A scissor, box cutter, or X-ACTO knife may be used in place of a wire cutter.
    • While cutting the foam, use gentle pressure to avoid damaging underlying wires.
    Ask FixBot
  10. Philips DS3000 Speakers Replacement: step 10, image 1 of 2 Philips DS3000 Speakers Replacement: step 10, image 2 of 2
    Soldering Iron 60w Hakko 503F
    $19.99
    Buy
    • Record where the wires connect to the speaker. When installing a new speaker, solder the wires onto those same points.
    • Heat up the solder securing the red wire using a soldering iron.
    • Remove the red wire.
    • Remove the black wire through the same process.
    • Handle a soldering iron with extreme care to avoid serious burns. Work in a well ventilated area to avoid inhaling solder fumes.
    Ask FixBot
  11. Philips DS3000 Speakers Replacement: step 11, image 1 of 1
    $19.99
    Buy
    • Strip a quarter inch of rubber insulation from each of the speaker wires (red and black) using a wire stripper’s 0.80 mm wire gauge.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Andrew McAuliffe
128 Reputation
1 Guide authored
1 Guide Comment
i hardly difficult to treat 2 defective speakers. i find the flat cable a little loose on the main plate. thank you!!!
araujojraa - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 41
All Time: 4,114
