Philips DPM8000 BA-Slider Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
125
All Time:
1,221
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Ensure to have the required spare parts lying next to you before your start disassembling the device.
You should also have a little bowl ready to set aside screws and other small parts.
Tools
    1. Philips DPM8000 BA-Slider Replacement, Anti-Static Wrist Strap: step 1, image 1 of 1
      Tool used on this step:
      $7.95
      Buy
      • Before you start disassembling your device make sure that it is turned off.
      • Put on the Anti-Static Wrist Strap and clamp the end of the band to an unpainted spot of a radiator.
      Ask FixBot
    2. Philips DPM8000 BA-Slider Replacement, Battery Lid: step 2, image 1 of 2 Philips DPM8000 BA-Slider Replacement, Battery Lid: step 2, image 2 of 2
      • Remove the battery lid
      Ask FixBot
    3. Philips DPM8000 BA-Slider Replacement, Battery: step 3, image 1 of 2 Philips DPM8000 BA-Slider Replacement, Battery: step 3, image 2 of 2
      • Remove the battery.
      • The battery lid is designed to function as an instrument for this task.
      Ask FixBot
    4. Philips DPM8000 BA-Slider Replacement, Upper Ornamental Part: step 4, image 1 of 3 Philips DPM8000 BA-Slider Replacement, Upper Ornamental Part: step 4, image 2 of 3 Philips DPM8000 BA-Slider Replacement, Upper Ornamental Part: step 4, image 3 of 3
      • Unscrew the six Torx #4 (5,3 mm) screws from both sides of the device
      • Collect the removed screws in a bowl or something comparable, otherwise they might get lost.
      Ask FixBot
    5. Philips DPM8000 BA-Slider Replacement: step 5, image 1 of 3 Philips DPM8000 BA-Slider Replacement: step 5, image 2 of 3 Philips DPM8000 BA-Slider Replacement: step 5, image 3 of 3
      • Remove the upper ornamental part from the housing.
      • If your fingernails are not long enough you can use a plastic opening tool.
      • When reassembling the device be aware that the six shackles on the sides of the upper ornamental part need to be placed inside the frame.
      Ask FixBot
    6. Philips DPM8000 BA-Slider Replacement, Housing/Display: step 6, image 1 of 2 Philips DPM8000 BA-Slider Replacement, Housing/Display: step 6, image 2 of 2
      • Lift up the housing.
      • The display as well as the speaker are connected to the motherboard. Therefore you need to be careful not to harm those connections.
      Ask FixBot
    7. Philips DPM8000 BA-Slider Replacement: step 7, image 1 of 2 Philips DPM8000 BA-Slider Replacement: step 7, image 2 of 2
      • Unlock the connection between display and motherboard by pushing open the brown cleat.
      • It is recommended to use a spudger or a comparable tool for this step.
      • If the connection is not completely open, one of the involved components could easily be harmed.
      Ask FixBot
    8. Philips DPM8000 BA-Slider Replacement: step 8, image 1 of 2 Philips DPM8000 BA-Slider Replacement: step 8, image 2 of 2
      • Separate the connection by pulling out the display cable.
      • If the cable does not come out easily, the connection is probably still locked.
      • When reconnecting the display to the motherboard don't forget to lock the connection, otherwise it will eventually come loose and you will have to redo the first eight steps of this guide.
      Ask FixBot
    1. Philips DPM8000 BA-Slider Replacement, Speaker: step 9, image 1 of 3 Philips DPM8000 BA-Slider Replacement, Speaker: step 9, image 2 of 3 Philips DPM8000 BA-Slider Replacement, Speaker: step 9, image 3 of 3
      Buy
      • Remove the mounting spring from the speaker with a pair of tweezers.
      • If you just want to replace the motherboard, it is recommended to ignore the steps 9 and 10.
      Ask FixBot
    2. Philips DPM8000 BA-Slider Replacement: step 10, image 1 of 2 Philips DPM8000 BA-Slider Replacement: step 10, image 2 of 2
      • Take off the safety mat from the speaker.
      • Remove the speaker from the housing.
      Ask FixBot
    3. Philips DPM8000 BA-Slider Replacement, Motherboard: step 11, image 1 of 2 Philips DPM8000 BA-Slider Replacement, Motherboard: step 11, image 2 of 2
      • Unscrew the eight Torx #4 (5,0 mm) screws from the motherboard.
      • These two screws connect the motherboard with the sliding cage. In this guide they are removed as well. Hence this is not compulsory you can decide for yourself whether you want to remove them now or later.
      Ask FixBot
    4. Philips DPM8000 BA-Slider Replacement: step 12, image 1 of 2 Philips DPM8000 BA-Slider Replacement: step 12, image 2 of 2
      • Push in the SD-Card to eject it.
      • If the memory card remains in its slot you will not be able to remove the motherboard.
      Ask FixBot
    5. Philips DPM8000 BA-Slider Replacement: step 13, image 1 of 2 Philips DPM8000 BA-Slider Replacement: step 13, image 2 of 2
      • Abstract the motherboard.
      • Lift up the motherboard as shown in the picture before completely removing it.
      • When inserting the motherboard first put in the side with the speaker jack on it and make sure that the microphone is placed properly under the motherboard.
      Ask FixBot
    1. Philips DPM8000 BA-Slider Replacement, BA-Slider: step 14, image 1 of 1
      • Remove the sliding cage.
      • When reassembling the device please make sure that the spring in the sliding cage is positioned on the bottom side of the device.
      Ask FixBot
    2. Philips DPM8000 BA-Slider Replacement: step 15, image 1 of 2 Philips DPM8000 BA-Slider Replacement: step 15, image 2 of 2
      • Unscrew one crossed slot screw PH00 (4,5 mm).
      Ask FixBot
    3. Philips DPM8000 BA-Slider Replacement: step 16, image 1 of 1
      • Remove the defective BA-Slider and replace it with the new one.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order beginning with step 15.
Andreas Holl
731 Reputation
6 Guides authored
Technische Universität Wien Member of Technische Universität Wien
Community
2 Members
72 Guides authored
2 Guide Comments
Großes Lob. Klare Anleitung. Scharfe Fotos. Gibt von 10/ 10 Punkte.
Michael Splittgerber - Reply Share
Hab noch vergessen, was an dem Gerät war. Der Schiebeschalter ging sehr schwer. Vermutlich war irgend etwas klebriges darunter. Ich habe den Schlitten gesäubert. Er geht wieder. Vielen Dank.
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 125
All Time: 1,221
