Up to 20% off select tools
Philips DC320 37 Connector Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
Past 7 Days:
4
Past 30 Days:
29
All Time:
1,665
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Tools
Introduction
Go to step 1 ↓
Follow the procedure outlined in this guide to remove and install a broken iPhone/iPod connector.
    1. Philips DC320 37 Connector Replacement, Docking entertainment system: step 1, image 1 of 1
      • Pry off the four white feet with the pointed end of the spudger
      Ask FixBot
    2. Philips DC320 37 Connector Replacement: step 2, image 1 of 1
      • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
      Ask FixBot
    3. Philips DC320 37 Connector Replacement: step 3, image 1 of 1
      • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
      • The connectors on the panel are fragile and may break.
      Ask FixBot
    4. Philips DC320 37 Connector Replacement: step 4, image 1 of 3 Philips DC320 37 Connector Replacement: step 4, image 2 of 3 Philips DC320 37 Connector Replacement: step 4, image 3 of 3
      • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
      • Electrical Connectors
      • Ribbon Connectors
      • The cables do not have a lot of slack in them. Be careful not to break the connectors.
      • One wire is soldered onto the bottom panel. Be careful not to break this bond.
      Ask FixBot
    1. Philips DC320 37 Connector Replacement, Connector: step 5, image 1 of 1
      • Pull the copper plate out of the way of the two Phillips #00 screws in the middle of the connector.
      Ask FixBot
    2. Philips DC320 37 Connector Replacement: step 6, image 1 of 1
      • Unscrew the two 7 mm Phillips #00 screws holding the connector together.
      • Unscrew the four 5 mm Phillips #00 screws holding the connector to the dock
      Ask FixBot
    3. Philips DC320 37 Connector Replacement: step 7, image 1 of 3 Philips DC320 37 Connector Replacement: step 7, image 2 of 3 Philips DC320 37 Connector Replacement: step 7, image 3 of 3
      • Turn the dock so that you are looking at the front of the dock.
      • Pull out the black U-shaped piece.
      • Pull out the iPhone/iPod support cradle.
      • Pull out the two springs.
      Ask FixBot
    4. Philips DC320 37 Connector Replacement: step 8, image 1 of 1
      • Turn the dock so that you are looking at the bottom of the dock.
      • Pop out the black connector frame and attached circuit board from the body of the dock.
      Ask FixBot
Author
with
Greg Lane
39 Reputation
4 Guides authored
Cal Poly, Team 3-48, Amido Spring 2013 Member of Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 29
All Time: 1,665
