Philips DC320 37 Bottom Button Circuit Board Replacement
  1. Philips DC320 37 Bottom Button Circuit Board Replacement, Docking entertainment system: step 1, image 1 of 1
    • Pry off the four white feet with the pointed end of the spudger
    Ask FixBot
  2. Philips DC320 37 Bottom Button Circuit Board Replacement: step 2, image 1 of 1
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
    Ask FixBot
  3. Philips DC320 37 Bottom Button Circuit Board Replacement: step 3, image 1 of 1
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
    Ask FixBot
  4. Philips DC320 37 Bottom Button Circuit Board Replacement: step 4, image 1 of 3 Philips DC320 37 Bottom Button Circuit Board Replacement: step 4, image 2 of 3 Philips DC320 37 Bottom Button Circuit Board Replacement: step 4, image 3 of 3
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
    Ask FixBot
  5. Philips DC320 37 Bottom Button Circuit Board Replacement, Bottom Button Circuit Board: step 5, image 1 of 1
    • Unscrew the ten 6 mm Phillips #00 screws holding the board in place.
    Ask FixBot
  6. Philips DC320 37 Bottom Button Circuit Board Replacement: step 6, image 1 of 1
    • Pull the board out from the dock
    Ask FixBot
Greg Lane
39 Reputation
4 Guides authored
Cal Poly, Team 3-48, Amido Spring 2013 Member of Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 Members
7 Guides authored
1 Guide Comment
My philips dc 320 /37 A do not sown time digits and frecvency digits . Where can I find schematic diagram?
Thank you
chioreangheorghe - Reply Share
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 1,113
