Philips BiPAP S/T Blower Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
76
All Time:
3,636
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Medical Equipment Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Introduction
Go to step 1 ↓
Under high usage the blower assembly is under a large amount of stress causing the whole unit to malfunction. Thus, needing to replace the whole blower.
For more information on replacing the blower assembly, please refer to page 6-16 in the service manual.
Parts
Tools
Video Overview
    1. Philips BiPAP S/T Blower  Replacement, Blower: step 1, image 1 of 1
      • Remove the UI Knob by pulling it straight out.
      Ask FixBot
    2. Philips BiPAP S/T Blower  Replacement: step 2, image 1 of 1
      • Remove the top cover by using a Torx T15 to remove the 2 screws on the back of the enclosure.
      Ask FixBot
    3. Philips BiPAP S/T Blower  Replacement: step 3, image 1 of 1
      • Remove the Main PCA by removing the wiring harnesses and squeezing the 2 standoffs in the corners of the board.
      Ask FixBot
    4. Philips BiPAP S/T Blower  Replacement: step 4, image 1 of 1
      • Remove the Blower Cap by using the T8 Torx screwdriver to remove the 7 screws that secure the Cap to the enclosure.
      Ask FixBot
      • Lift the Blower Assembly out of the blower housing.
      • Remove the blower Outlet Bellows from the blower assembly.
      Ask FixBot
      • Place the New outlet bellows onto the blower assembly.
      Ask FixBot
    5. Philips BiPAP S/T Blower  Replacement: step 7, image 1 of 1
      • Align the stands located on the bottom of the blower assembly with the holes in the blower housing.
      Ask FixBot
2 other people completed this guide.
Benjamin LaVigna
243 Reputation
1 Guide authored
Cal Poly, Team S7-G3, Paton Spring 2020 Member of Cal Poly, Team S7-G3, Paton Spring 2020
CPSU-PATON-S20S7G3
3 Members
36 Guides authored
1 Guide Comment
this was super helpful. i yanked a working motor/blower from a slightly older system one unit that had a dead humidifier circuit(found it had melted the connector inside) and moved it to my newer bipap unit. works great, dead silent. mine had bad bearings…so loud. great article. thank you for saving me money, time…..SLEEP!
Jon Harmon - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 76
All Time: 3,636
