This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Phase 2 LAÇATUDO Electronic Board
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
61
All Time:
216
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Very easy
Community-Contributed Guide
    1. Phase 2 LAÇATUDO Electronic Board, Top Cover: step 1, image 1 of 2 Phase 2 LAÇATUDO Electronic Board, Top Cover: step 1, image 2 of 2
      • Unplug the Laça tudo before you begin disassembling it.
      • Then, remove the 2 MAQ screws installed on the rear of the machine's top cover, and afterwards remove the 2 MAQ CHAT screws on the top using a 1/8 Phillips screwdriver. (Photo 1)
      • With the screws removed, take off the top cover. (Photo 2)
      Ask FixBot
    2. Phase 2 LAÇATUDO Electronic Board: step 2, image 1 of 3 Phase 2 LAÇATUDO Electronic Board: step 2, image 2 of 3 Phase 2 LAÇATUDO Electronic Board: step 2, image 3 of 3
      • Now we will remove the rear cover; to do this, remove the 5 MAQ Phillips screws secured to the back of the machine.
      • After removing the screws, disconnect the mini-fan connector from the electronic board.
      • To do this, pull out the white 2-wire connector. (Photos 2 and 3)
      • When reassembling, follow the wiring diagram; each male connector has a specific color and must be connected to the female connector of the same color and number of wires.
      Ask FixBot
    3. Phase 2 LAÇATUDO Electronic Board: step 3, image 1 of 1
      • After removing the cover screws and the Mini fan connector, remove the back cover. (Photo 1)
      Ask FixBot
    1. Phase 2 LAÇATUDO Electronic Board, Phase 2 LAÇATUDO Electronic Board: step 4, image 1 of 3 Phase 2 LAÇATUDO Electronic Board, Phase 2 LAÇATUDO Electronic Board: step 4, image 2 of 3 Phase 2 LAÇATUDO Electronic Board, Phase 2 LAÇATUDO Electronic Board: step 4, image 3 of 3
      • The next step is to disconnect all board connectors,
      • During reassembly, follow the wiring diagram; each male connector has a specific color and must be connected to the female connector of the same color and number of wires.
      • Most connectors are plug-in type, and to remove them, just pull the connector. (Photos 1 and 2)
      • The only connectors that are not plug-in type are the KRE connectors, and to disconnect the wires, it is necessary to use a screwdriver.
      • Remember to identify the cables and follow the wiring diagram.
      Ask FixBot
    2. Phase 2 LAÇATUDO Electronic Board: step 5, image 1 of 2 Phase 2 LAÇATUDO Electronic Board: step 5, image 2 of 2
      • Now, remove the 4 Phillips screws installed on each side of the circuit board. (Photo 1)
      • After that, remove the board.
      • For reassembly, follow the Electrical Diagram
      Ask FixBot
Lacito
6,169 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 61
All Time: 216
