Petcube Play 2 Motherboard Replacement
  1. Petcube Play 2 Motherboard Replacement, Motherboard: step 1, image 1 of 3 Petcube Play 2 Motherboard Replacement, Motherboard: step 1, image 2 of 3 Petcube Play 2 Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Flip over the Petcube so the rubber bottom faces you.
    • Pull up the rubber layer with an iFixit opening pick to expose the screws underneath.
    Ask FixBot
  2. Petcube Play 2 Motherboard Replacement: step 2, image 1 of 2 Petcube Play 2 Motherboard Replacement: step 2, image 2 of 2
    • Remove the four 3.5mm screws from under the rubber cover using a Phillips #1 screwdriver.
    • The glue may cause slight resistance, but the screws should come out with minimal effort.
    Ask FixBot
  3. Petcube Play 2 Motherboard Replacement: step 3, image 1 of 2 Petcube Play 2 Motherboard Replacement: step 3, image 2 of 2
    • Carefully pry off the glass front panel using an opening pick or a spudger.
    • Do not force the front panel off, as it may crack and break.
    Ask FixBot
  4. Petcube Play 2 Motherboard Replacement: step 4, image 1 of 3 Petcube Play 2 Motherboard Replacement: step 4, image 2 of 3 Petcube Play 2 Motherboard Replacement: step 4, image 3 of 3
    • Slide off the two covers, starting with the top plastic cover.
    • Slide out the internal assembly from the aluminum casing.
    Ask FixBot
  5. Petcube Play 2 Motherboard Replacement: step 5, image 1 of 3 Petcube Play 2 Motherboard Replacement: step 5, image 2 of 3 Petcube Play 2 Motherboard Replacement: step 5, image 3 of 3
    • Once the internal assembly is removed, a brass cylinder in one corner of the cube's front face will be visible. A screw will be attached to it.
    • Remove the screw with a Phillips #1 screwdriver.
    Ask FixBot
  6. Petcube Play 2 Motherboard Replacement: step 6, image 1 of 3 Petcube Play 2 Motherboard Replacement: step 6, image 2 of 3 Petcube Play 2 Motherboard Replacement: step 6, image 3 of 3
    • Flip the cube onto its side to locate the pull tabs.
    • Using an opening tool, lift each of the five tabs to separate the two halves of the Petcube 2.
    Ask FixBot
  7. Petcube Play 2 Motherboard Replacement: step 7, image 1 of 3 Petcube Play 2 Motherboard Replacement: step 7, image 2 of 3 Petcube Play 2 Motherboard Replacement: step 7, image 3 of 3
    • Gently disconnect the cable connectors to separate the two halves of the device.
    • Avoid pulling on the wires to prevent damage to the connectors.
    Ask FixBot
  8. Petcube Play 2 Motherboard Replacement: step 8, image 1 of 3 Petcube Play 2 Motherboard Replacement: step 8, image 2 of 3 Petcube Play 2 Motherboard Replacement: step 8, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the two 1mm screws.
    • Carefully release each of the tabs on the sides of the cube and remove the motherboard.
    • Be gentle with the tabs. They will break under too much pressure.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Jacob Branco
291 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 314
