Tools
Spudger4.9
Introduction
Go to step 1 ↓If the camera of your Petcube Play 2 (identified by model number PP2OUS) is malfunctioning, use this guide to replace it.
The Petcube Play 2 comes with a built-in camera that can record and stream videos of your pet to your phone. A defective camera might lead to poor video quality, skipping, or recording failures.
Before using this guide, ensure that there are no connection issues between the Petcube, your Wi-Fi router, and your phone. The Troubleshooting Page covers connection and video quality-related issues and how to address them.
Ensure the Petcube Play 2 is turned off before beginning the replacement process.
Flip over the Petcube so the rubber bottom faces you.
Pull up the rubber layer with an iFixit opening pick to expose the screws underneath.
Use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
