Pentax ZX-5n Top Cover Replacement
    1. Pentax ZX-5n Top Cover Replacement, Remove back cover: step 1, image 1 of 1
      • Push down on the screw to depress the spring loaded hinge and release the door.
      Ask FixBot
    2. Pentax ZX-5n Top Cover Replacement, Remove bottom cover: step 2, image 1 of 1
      • Remove six 5.3 mm #00 screws.
      • Remove one 3.4 mm #00 screw.
      • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
      Ask FixBot
    3. Pentax ZX-5n Top Cover Replacement, Remove left front cover: step 3, image 1 of 1
      • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
      • Remove one 7.3 mm #00 screw.
      • Remove the remote trigger cover.
      Ask FixBot
    4. Pentax ZX-5n Top Cover Replacement, Remove front cover: step 4, image 1 of 2 Pentax ZX-5n Top Cover Replacement, Remove front cover: step 4, image 2 of 2
      • Remove two 5.3 mm #00 screw.
      • Gently lift up on the flash housing to help remove the cover if necessary.
      Ask FixBot
    5. Pentax ZX-5n Top Cover Replacement, Remove right front cover: step 5, image 1 of 1
      • Remove two 3.9 mm #00 screws.
      Ask FixBot
    1. Pentax ZX-5n Top Cover Replacement, Remove eye cup: step 6, image 1 of 1
      • Slide the eye cup up and off to access the screws underneath.
      Ask FixBot
    2. Pentax ZX-5n Top Cover Replacement, Unscrew top cover: step 7, image 1 of 3 Pentax ZX-5n Top Cover Replacement, Unscrew top cover: step 7, image 2 of 3 Pentax ZX-5n Top Cover Replacement, Unscrew top cover: step 7, image 3 of 3
      • Remove two 5.3 mm #00 screws by the eyepiece.
      • Remove one 6.8 mm #00 screw in the battery compartment.
      • Remove one 7.0 mm #00 screw near the take up spool.
      Ask FixBot
    3. Pentax ZX-5n Top Cover Replacement, Lift top cover: step 8, image 1 of 1
      • Lift the cover so it is just free of the body. It is still attached by several wires.
      Ask FixBot
    4. Pentax ZX-5n Top Cover Replacement, Discharge flash capacitors: step 9, image 1 of 1
      • Use a 1kΩ-10kΩ resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
      • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
      Ask FixBot
    5. Pentax ZX-5n Top Cover Replacement, Unsolder flash connections: step 10, image 1 of 1
      • Unsolder one green wire.
      • Unsolder one blue wire.
      • Unsolder one brown wire.
      • Unsolder one black wire.
      Ask FixBot
    6. Pentax ZX-5n Top Cover Replacement, Unsolder remaining connections: step 11, image 1 of 3 Pentax ZX-5n Top Cover Replacement, Unsolder remaining connections: step 11, image 2 of 3 Pentax ZX-5n Top Cover Replacement, Unsolder remaining connections: step 11, image 3 of 3
      • Pull black wire out from its routed location.
      • Unsolder flex connector
      • Be careful not to overheat the flex circuit. Work in short durations. Allow for cool downs in between if necessary.
      • Some repairs can be performed with the top cover still connected but the flex connection is fragile and easily damaged.
      Ask FixBot
Sam Gustafson
14,514 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 267
