Pentax ZX-5n Sprocket Counter PCB Replacement
  1. Pentax ZX-5n Sprocket Counter PCB Replacement, Remove back cover: step 1, image 1 of 1
    • Push down on the screw to depress the spring loaded hinge and release the door.
  2. Pentax ZX-5n Sprocket Counter PCB Replacement, Remove bottom cover: step 2, image 1 of 1
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
  3. Pentax ZX-5n Sprocket Counter PCB Replacement, Remove left front cover: step 3, image 1 of 1
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
  4. Pentax ZX-5n Sprocket Counter PCB Replacement, Remove front cover: step 4, image 1 of 2 Pentax ZX-5n Sprocket Counter PCB Replacement, Remove front cover: step 4, image 2 of 2
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
  5. Pentax ZX-5n Sprocket Counter PCB Replacement, Remove right front cover: step 5, image 1 of 1
    • Remove two 3.9 mm #00 screws.
  6. Pentax ZX-5n Sprocket Counter PCB Replacement, Prepare bottom plate: step 6, image 1 of 2 Pentax ZX-5n Sprocket Counter PCB Replacement, Prepare bottom plate: step 6, image 2 of 2
    • Remove two 3.4 mm #00 screws. Remove the plate holding the contacts in place.
    • Peel tape from the plate. Leave the tape attached to the flex circuit.
    • Remove the flex circuits from their retaining studs.
  7. Pentax ZX-5n Sprocket Counter PCB Replacement, Remove bottom plate: step 7, image 1 of 2 Pentax ZX-5n Sprocket Counter PCB Replacement, Remove bottom plate: step 7, image 2 of 2
    • Remove one 3.3 mm #0 countersunk screw.
    • Remove one 3.9 mm #0 shoulder screw.
    • Remove four 3.3 mm #00 screws.
    • Pull a little slack through the housing on this flex cable.
    • Pop the plate off its posts, rotate slightly clockwise and pull gently through the loosened flex cable.
    • To the camera tech that left me a happy little note...I see you.
  8. Pentax ZX-5n Sprocket Counter PCB Replacement, Remove transport gears: step 8, image 1 of 2 Pentax ZX-5n Sprocket Counter PCB Replacement, Remove transport gears: step 8, image 2 of 2
    • It's best to remove these parts now so they don't fall out later on in the repair.
  9. Pentax ZX-5n Sprocket Counter PCB Replacement, Remove transport gear carrier: step 9, image 1 of 3 Pentax ZX-5n Sprocket Counter PCB Replacement, Remove transport gear carrier: step 9, image 2 of 3 Pentax ZX-5n Sprocket Counter PCB Replacement, Remove transport gear carrier: step 9, image 3 of 3
    • Gently pull the speaker from its retention posts.
    • Remove two 5.1 mm #00 screws.
    • Installation Notes: The transport gear carrier mates with the sprocket shaft here using a squared off spindle. Make sure they mate properly when reassembled.
  10. Pentax ZX-5n Sprocket Counter PCB Replacement, Remove sprocket counter PCB: step 10, image 1 of 2 Pentax ZX-5n Sprocket Counter PCB Replacement, Remove sprocket counter PCB: step 10, image 2 of 2
    • Remove one X mm screw.
    • The screw has atypical threads with a very steep angle. It will want to move in/out with relatively little rotation.
    • Unsolder one purple wire.
    • Unsolder one yellow wire.
2 other people completed this guide.
Sam Gustafson
10,775 Reputation
74 Guides authored
4 Guide Comments
I replaced that pcb component,but these gaps are not stable. Sometimes wide sometimes overlap.Do you have any solutions about this problem?
zhong liu - Reply Share
Hmm, that's a bummer. First I would make sure that your replacement PCB looks like this. The green color isn't important but the contacts should be gold not silver.
https://www.pentaxforums.com/forums/8-fi...
You might have to double check the installation, make sure no debris or hairs got in the mechanism. Make sure the sweepers didn't get bent or misshapen.
I will say that the converted camera may not give you perfect results. I usually get about one frame overlap per roll, but the vast majority of frames are good. It's not uncommon for even stock MZ cameras to have frame advance issues, so it might be related to the mod or it might not.
Sam Gustafson - Reply Share
I solved it! Although the gap is unstable but it has some rhythm. Also! There is no overlap anymore!
My pcb component is silver,not gold.I think it might caused by the film mask which is cut from instaxfilm cover.Maybe too thick that can’t properly advancing film.I will try to stick it direct in the full frame area.hhhhhhh hopefully might help,otherwise I have to get some gold pcb….
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 428
