Pentax Spotmatic Viewfinder Removal
  1. Pentax Spotmatic Viewfinder Removal, Remove frame counter: step 1, image 1 of 3 Pentax Spotmatic Viewfinder Removal, Remove frame counter: step 1, image 2 of 3 Pentax Spotmatic Viewfinder Removal, Remove frame counter: step 1, image 3 of 3
    • Loosen three grub screws. Do not remove them from the frame counter cover.
    • Lift off frame counter cover.
    • Remove one 2.5 mm flat head screw. It is reverse or left-hand threaded.
    • Remove the frame counter dial.
    • Remove the retaining nut using a spanner wrench. A pair of fine tipped nippers can also work.
    • On some Spotmatics, this nut may be reverse threaded. Work carefully.
    • Remove the dial seat.
    Ask FixBot
  2. Pentax Spotmatic Viewfinder Removal, Remove advance lever: step 2, image 1 of 3 Pentax Spotmatic Viewfinder Removal, Remove advance lever: step 2, image 2 of 3 Pentax Spotmatic Viewfinder Removal, Remove advance lever: step 2, image 3 of 3
    • Remove three 2.3 mm flat head screws.
    • Use a pick to rotate the retaining washer until the lobed sections are free.
    • Lift off the advance lever.
    • Remove the plastic shim washer.
    Ask FixBot
  3. Pentax Spotmatic Viewfinder Removal, Remove shutter speed dial: step 3, image 1 of 3 Pentax Spotmatic Viewfinder Removal, Remove shutter speed dial: step 3, image 2 of 3 Pentax Spotmatic Viewfinder Removal, Remove shutter speed dial: step 3, image 3 of 3
    • Remove one 2.8 mm pin head screw.
    • The dial assembly is spring loaded. Keep two fingers on top of the dial as you are loosening the screw to prevent it from popping off.
    • Remove the shutter speed dial.
    • Remove the ISO dial.
    • Remove the internal spring.
    • Remove the dial housing.
    Ask FixBot
  4. Pentax Spotmatic Viewfinder Removal, Installation Notes: Shutter Speed Dial: step 4, image 1 of 2 Pentax Spotmatic Viewfinder Removal, Installation Notes: Shutter Speed Dial: step 4, image 2 of 2
    • The hole in the dial housing needs to go over the tab on the speed resistor.
    • The tab on the ISO dial needs to mate with the hole in the dial housing.
    • It can be difficult to line everything up while compressing the spring and installing the center screw. Be patient.
    Ask FixBot
  5. Pentax Spotmatic Viewfinder Removal, Remove film winder assembly: step 5, image 1 of 3 Pentax Spotmatic Viewfinder Removal, Remove film winder assembly: step 5, image 2 of 3 Pentax Spotmatic Viewfinder Removal, Remove film winder assembly: step 5, image 3 of 3
    • Place a thin, sturdy tool in the spindle fork.
    • Unscrew the rewind knob.
    • Use a spanner wrench to unscrew the retaining nut.
    • Remove the film reminder
    • Remove the spring washer.
    • Remove the friction plate.
    Ask FixBot
  6. Pentax Spotmatic Viewfinder Removal, Remove top cover: step 6, image 1 of 2 Pentax Spotmatic Viewfinder Removal, Remove top cover: step 6, image 2 of 2
    • Remove one 3.0 mm flat head screw.
    • Remove top cover.
    Ask FixBot
  7. Pentax Spotmatic Viewfinder Removal, Unsolder meter circuit: step 7, image 1 of 2 Pentax Spotmatic Viewfinder Removal, Unsolder meter circuit: step 7, image 2 of 2
    • Unscrew or unsolder one black wire. This is the main power coming from the meter switch on the side of the mirror box.
    • Unscrew one blue wire. This is the ground wire that connects the meter circuit to the body of the camera.
    • Unsolder one yellow and one black wire from the speed resistor.
    Ask FixBot
  8. Pentax Spotmatic Viewfinder Removal, Remove viewfinder assembly: step 8, image 1 of 2 Pentax Spotmatic Viewfinder Removal, Remove viewfinder assembly: step 8, image 2 of 2
    • Remove three 5.7 mm flat head screws.
    • Lift out the viewfinder assembly.
    • The pentaprism, eye piece and meter circuit will come out with the viewfinder.
    Ask FixBot
Sam Gustafson
11,000 Reputation
78 Guides authored
3 Guide Comments
Very clear description of the procedure to remove the top cover and of course the pentaprism and view finder . Great photographs to accompany each step and so well presented, could not be bettered. So that many thanks indeed - very very helpful. regards mark
mark steed - Reply Share
I got the same camera from my brother but the lever to cock/charge the camera and film is not working. I can turn it but it feels like the gear is slipping. Sometimes when I help turning the cylinder that pulls on the film I can get it to the ready position to take a photo but it's not consistent. Do you have any idea if I can fix that on my own?
Linus - Reply Share
Hmm, hard to pinpoint what the problem would be from your description. Unfortunately, outside of a few well known failures, diagnosing a problem usually involves disassembling the camera and examining the internal mechanisms. Look for broken parts, or stuck levers, that sort of thing. Whether or not it's doable for you just depends on how comfortable you are tinkering with these kinds of things.
Sam Gustafson - Reply Share
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 72
All Time: 1,140
