Pentax Spotmatic Top Cover Removal
    1. Pentax Spotmatic Top Cover Removal, Remove frame counter: step 1, image 1 of 3 Pentax Spotmatic Top Cover Removal, Remove frame counter: step 1, image 2 of 3 Pentax Spotmatic Top Cover Removal, Remove frame counter: step 1, image 3 of 3
      • Loosen three grub screws. Do not remove them from the frame counter cover.
      • Lift off frame counter cover.
      • Remove one 2.5 mm flat head screw. It is reverse or left-hand threaded.
      • Remove the frame counter dial.
      • Remove the retaining nut using a spanner wrench. A pair of fine tipped nippers can also work.
      • On some Spotmatics, this nut may be reverse threaded. Work carefully.
      • Remove the dial seat.
      Ask FixBot
    2. Pentax Spotmatic Top Cover Removal, Remove advance lever: step 2, image 1 of 3 Pentax Spotmatic Top Cover Removal, Remove advance lever: step 2, image 2 of 3 Pentax Spotmatic Top Cover Removal, Remove advance lever: step 2, image 3 of 3
      • Remove three 2.3 mm flat head screws.
      • Use a pick to rotate the retaining washer until the lobed sections are free.
      • Lift off the advance lever.
      • Remove the plastic shim washer.
      Ask FixBot
    3. Pentax Spotmatic Top Cover Removal, Remove shutter speed dial: step 3, image 1 of 3 Pentax Spotmatic Top Cover Removal, Remove shutter speed dial: step 3, image 2 of 3 Pentax Spotmatic Top Cover Removal, Remove shutter speed dial: step 3, image 3 of 3
      • Remove one 2.8 mm pin head screw.
      • The dial assembly is spring loaded. Keep two fingers on top of the dial as you are loosening the screw to prevent it from popping off.
      • Remove the shutter speed dial.
      • Remove the ISO dial.
      • Remove the internal spring.
      • Remove the dial housing.
      Ask FixBot
    4. Pentax Spotmatic Top Cover Removal, Installation Notes: Shutter Speed Dial: step 4, image 1 of 2 Pentax Spotmatic Top Cover Removal, Installation Notes: Shutter Speed Dial: step 4, image 2 of 2
      • The hole in the dial housing needs to go over the tab on the speed resistor.
      • The tab on the ISO dial needs to mate with the hole in the dial housing.
      • It can be difficult to line everything up while compressing the spring and installing the center screw. Be patient.
      Ask FixBot
    5. Pentax Spotmatic Top Cover Removal, Remove film winder assembly: step 5, image 1 of 3 Pentax Spotmatic Top Cover Removal, Remove film winder assembly: step 5, image 2 of 3 Pentax Spotmatic Top Cover Removal, Remove film winder assembly: step 5, image 3 of 3
      • Place a thin, sturdy tool in the spindle fork.
      • Unscrew the rewind knob.
      • Use a spanner wrench to unscrew the retaining nut.
      • Remove the film reminder
      • Remove the spring washer.
      • Remove the friction plate.
      Ask FixBot
    6. Pentax Spotmatic Top Cover Removal, Remove top cover: step 6, image 1 of 2 Pentax Spotmatic Top Cover Removal, Remove top cover: step 6, image 2 of 2
      • Remove one 3.0 mm flat head screw.
      • Remove top cover.
      Ask FixBot
Sam Gustafson
14,484 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 119
All Time: 1,613
