Pentax Spotmatic Light Meter Calibration
  1. Pentax Spotmatic Light Meter Calibration, Open film door: step 1, image 1 of 1
    • Open the flim door.
    Ask FixBot
  2. Pentax Spotmatic Light Meter Calibration, Remove the rewind knob: step 2, image 1 of 3 Pentax Spotmatic Light Meter Calibration, Remove the rewind knob: step 2, image 2 of 3 Pentax Spotmatic Light Meter Calibration, Remove the rewind knob: step 2, image 3 of 3
    • Place a thin, sturdy tool in the spindle fork.
    • Unscrew the rewind knob.
    • Use a spanner wrench to unscrew the retaining nut.
    • Remove the film reminder
    • Remove the spring washer.
    • Remove the friction plate.
    • Keep the film door open for the duration of the light meter adjustment. It can be difficult to open without the rewind knob installed.
    Ask FixBot
    • Mount a lens on the camera.
    • Create a scene of known brightness in front of the camera.
    • Adjust the aperture, shutter speed and ISO to achieve proper exposure for the chosen scene.
    • Switch on the light meter.
    Ask FixBot
  3. Pentax Spotmatic Light Meter Calibration, Make adjustments: step 4, image 1 of 2 Pentax Spotmatic Light Meter Calibration, Make adjustments: step 4, image 2 of 2
    • Use a pick to adjust the variable resistor through the opening in the top plate.
    • Turn it until the needle in the viewfinder is centered in the opening, indicating a proper exposure.
    • The adjustment resistor shown with the top cover removed.
    • Repeat steps 3 and 4 for several different light levels.
    • Since the Spotmatic only has one adjustment resistor, it may not be possible to center the needle at every light level. Make compromises as necessary.
    Ask FixBot
Sam Gustafson
11,000 Reputation
78 Guides authored
1 Guide Comment
ABSOLUTELY make sure to NOT pull out the spindle fork. I say that because although the guide doesn't make that mistake, it doesn't explicitly tell you to avoid it either. If you already pulled it out and are now unable to get it back in because of that spring, I would recommend you set aside about 30 minutes with a really small and really thin piece of metal and try to push that spring back. I solved it using a snapped-off piece of a double edge razor blade.
Jean Cox - Reply Share
Past 24 Hours: 7
Past 7 Days: 53
Past 30 Days: 135
All Time: 2,517
