Pentax Optio WP Battery and SD Card Replacement
    1. Pentax Optio WP Battery and SD Card Replacement, Battery and SD Card: step 1, image 1 of 1
      • The camera used to make this manual does not contain a battery or SD card
      • Orient the camera so you are looking at the bottom and the battery compartment is on the right hand side.
      Ask FixBot
    2. Pentax Optio WP Battery and SD Card Replacement: step 2, image 1 of 2 Pentax Optio WP Battery and SD Card Replacement: step 2, image 2 of 2
      • Unlock the battery compartment by sliding the lock switch to the unlock position (away from the arrow).
      • Firmly push the battery cover to the right and swing open.
      • The battery will be located in the larger bottom slot. Slide the plastic orange tab to remove the battery.
      • The SD card will be located in the smaller, top slot. Push the SD card directly in to hear a small clicking sound. Then pull out the SD card.
      Ask FixBot
Olivia Nixon
429 Reputation
4 Guides authored
Cal Poly, Team 1-13, Amido Winter 2011 Member of Cal Poly, Team 1-13, Amido Winter 2011
CPSU-AMIDO-W11S1G13
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 93
All Time: 5,155
