Up to 20% off select tools
Pentax Optio WP Back Casing Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
99
All Time:
2,406
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will provide you with step-by-step help for removing the back casing on the Pentax Optio WP Digital Camera.
    1. Pentax Optio WP Back Casing Replacement, Battery and SD Card: step 1, image 1 of 1
      • The camera used to make this manual does not contain a battery or SD card
      • Orient the camera so you are looking at the bottom and the battery compartment is on the right hand side.
      Ask FixBot
    2. Pentax Optio WP Back Casing Replacement: step 2, image 1 of 2 Pentax Optio WP Back Casing Replacement: step 2, image 2 of 2
      • Unlock the battery compartment by sliding the lock switch to the unlock position (away from the arrow).
      • Firmly push the battery cover to the right and swing open.
      • The battery will be located in the larger bottom slot. Slide the plastic orange tab to remove the battery.
      • The SD card will be located in the smaller, top slot. Push the SD card directly in to hear a small clicking sound. Then pull out the SD card.
      Ask FixBot
    1. Pentax Optio WP Back Casing Replacement, Back Casing: step 3, image 1 of 2 Pentax Optio WP Back Casing Replacement, Back Casing: step 3, image 2 of 2
      • With the battery cover swung open, use the spudger to remove the DC IN sticker.
      • Remove the 4.3 mm silver screw revealed.
      Ask FixBot
    2. Pentax Optio WP Back Casing Replacement: step 4, image 1 of 2 Pentax Optio WP Back Casing Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Reorient the camera so it is upright and you are looking at the back screen.
      • Remove the rubber covers in the upper and lower right side corners. Insert spudger in between the camera case and the rubber cover and push them out of their sockets. Grab the rubbers with the tweezers and set them aside. Remove both of the 4.3 mm silver screws revealed.
      • Remove the 4.3 mm silver screw in the lower left corner which resides under the sliding battery cover.
      • When removing the screw in the lower left corner, you may need to gently pry open the casing to dislodge the screw.
      Ask FixBot
    3. Pentax Optio WP Back Casing Replacement: step 5, image 1 of 1
      • Locate the 5.3mm silver screw on the edge closest to the upper left corner of the LCD screen and remove it.
      Ask FixBot
    4. Pentax Optio WP Back Casing Replacement: step 6, image 1 of 3 Pentax Optio WP Back Casing Replacement: step 6, image 2 of 3 Pentax Optio WP Back Casing Replacement: step 6, image 3 of 3
      • With the spudger, pry back the cover starting with the outer edge to release.
      • Lift the back cover off gently from left to right. Be cautious of the copper ribbon attached to the back buttons.
      • Detach the copper ribbon from the internals of the camera by placing a finger on top of the terminal and gently pulling on the back casing.
      Ask FixBot
Author
with
Olivia Nixon
429 Reputation
4 Guides authored
Cal Poly, Team 1-13, Amido Winter 2011 Member of Cal Poly, Team 1-13, Amido Winter 2011
CPSU-AMIDO-W11S1G13
5 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 99
All Time: 2,406
