Pentax Optio WG-3 GPS Shutter and Power Button Replacement
  1. Pentax Optio WG-3 GPS Shutter and Power Button Replacement, Shutter and Power Button: step 1, image 1 of 1
    Tool used on this step:
    Buy
    • Peel the lining back on the top of the camera.
    • The lining is glued down to the device, you will have to peel the lining back using tweezers. After you are finished with your work you will have to use glue or adhesive to re-stick the lining back to the device.
    Ask FixBot
  2. Pentax Optio WG-3 GPS Shutter and Power Button Replacement: step 2, image 1 of 1
    • Using tweezers pull straight up to remove the 2 rubber button toppers
    Ask FixBot
  3. Pentax Optio WG-3 GPS Shutter and Power Button Replacement: step 3, image 1 of 1
    • Remove the 3, 2 mm screws under the rubber buttons.
    Ask FixBot
  4. Pentax Optio WG-3 GPS Shutter and Power Button Replacement: step 4, image 1 of 1
    • Replace the shutter/power button or button component.
    Ask FixBot
Allison Merdian
422 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 42
All Time: 934
