Pentax Optio WG-3 GPS Lens Assembly Replacement
  1. Pentax Optio WG-3 GPS Lens Assembly  Replacement, Lens Assembly: step 1, image 1 of 1
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
    Ask FixBot
  2. Pentax Optio WG-3 GPS Lens Assembly  Replacement: step 2, image 1 of 1
    • Flip over the camera so the bottom is facing up.
    • Remove the single Phillips #000 screw.
    • Remove the cover.
    Ask FixBot
  3. Pentax Optio WG-3 GPS Lens Assembly  Replacement: step 3, image 1 of 1
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
    Ask FixBot
  4. Pentax Optio WG-3 GPS Lens Assembly  Replacement: step 4, image 1 of 1
    • Carefully remove the circuitry.
    Ask FixBot
  5. Pentax Optio WG-3 GPS Lens Assembly  Replacement: step 5, image 1 of 1
    • Flip the circuitry so that the lens is facing up and the flash component is on your right.
    • Identify the orange ribbon tape surrounding the lens.
    Ask FixBot
  6. Pentax Optio WG-3 GPS Lens Assembly  Replacement: step 6, image 1 of 1
    • There are three 5 mm Phillips #000 screws to be removed on the right side of the lens.
    Ask FixBot
  7. Pentax Optio WG-3 GPS Lens Assembly  Replacement: step 7, image 1 of 1
    • Gently slide the lens piece to the right, remove the tape and take it out.
    Ask FixBot
Garrett Rose
373 Reputation
2 Guides authored
IUPUI, Team 3-1, Harley Spring 2022 Member of IUPUI, Team 3-1, Harley Spring 2022
IUPUI-HARLEY-S22S3G1
3 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 28
All Time: 552
