Pentax Optio WG-2 Memory Card Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
93
All Time:
1,249
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 seconds
Difficulty: Very easy
Introduction
Go to step 1 ↓
The Pentax Optio WG-2 uses SD memory cards. If your screen is not displaying anything, a faulty memory card may be the issue. Use this guide to replace the memory card of your Pentax Optio WG-2.
    1. Pentax Optio WG-2 Memory Card Replacement, Memory Card: step 1, image 1 of 3 Pentax Optio WG-2 Memory Card Replacement, Memory Card: step 1, image 2 of 3 Pentax Optio WG-2 Memory Card Replacement, Memory Card: step 1, image 3 of 3
      • Make sure the camera is turned off before removing or inserting the SD Memory Card.
      • Press the lock lever (small tab) in an upward direction towards the word open.
      • Slide the cover away from the camera.
      • Lift the cover up to gain access to the memory card.
      Ask FixBot
    2. Pentax Optio WG-2 Memory Card Replacement: step 2, image 1 of 2 Pentax Optio WG-2 Memory Card Replacement: step 2, image 2 of 2
      • To remove the SD Memory Card, push it in once and then pull it out.
      Ask FixBot
Chris Gudiel
123 Reputation
1 Guide authored
USF Tampa, Team 1-4, Sullivan Spring 2017 Member of USF Tampa, Team 1-4, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G4
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 93
All Time: 1,249
