Pentax Optio S4i Front and Back Cover Replacement
  1. Pentax Optio S4i Front and Back Cover Replacement, Front and Back Cover: step 1, image 1 of 2 Pentax Optio S4i Front and Back Cover Replacement, Front and Back Cover: step 1, image 2 of 2
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
    Ask FixBot
  2. Pentax Optio S4i Front and Back Cover Replacement: step 2, image 1 of 1
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
    Ask FixBot
  3. Pentax Optio S4i Front and Back Cover Replacement: step 3, image 1 of 2 Pentax Optio S4i Front and Back Cover Replacement: step 3, image 2 of 2
    • Carefully pull the back of casing away from the front.
    Ask FixBot
  4. Pentax Optio S4i Front and Back Cover Replacement: step 4, image 1 of 3 Pentax Optio S4i Front and Back Cover Replacement: step 4, image 2 of 3 Pentax Optio S4i Front and Back Cover Replacement: step 4, image 3 of 3
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
    Ask FixBot
  5. Pentax Optio S4i Front and Back Cover Replacement: step 5, image 1 of 2 Pentax Optio S4i Front and Back Cover Replacement: step 5, image 2 of 2
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
    Ask FixBot
Nicole Wong
371 Reputation
3 Guides authored
Cal Poly, Team 4-29, Regan Winter 2011 Member of Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 44
All Time: 3,766
