Pentax MX Shutter Curtains Disassembly
View statistics:
Past 24 Hours:
12
Past 7 Days:
41
Past 30 Days:
149
All Time:
331
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 week
Difficulty: Very difficult
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide is incomplete and doesn't contain all of the details necessary for reassembling the shutter. But it does contain useful information and may be a helpful reference for some people. If the shutter is very dirty this amount of disassembly is necessary to clean all of the sliding surfaces of the curtain shafts and winding gears. It is also be necessary for shutter curtain replacement.
Tools
    1. Pentax MX Shutter Curtains Disassembly, Remove film advance lever: step 1, image 1 of 3 Pentax MX Shutter Curtains Disassembly, Remove film advance lever: step 1, image 2 of 3 Pentax MX Shutter Curtains Disassembly, Remove film advance lever: step 1, image 3 of 3
      • Remove the lever cap. The cap is reverse threaded.
      • Lift off the advance lever.
      • Remove the collar beneath the lever.
      Ask FixBot
    2. Pentax MX Shutter Curtains Disassembly, Remove shutter speed dial: step 2, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove shutter speed dial: step 2, image 2 of 2
      • Set the ISO to 100 and the shutter speed to 1000.
      • Remove one pin head screw.
      • Lift off shutter speed dial.
      • Remove the collar beneath the dial.
      • Installation Notes: Make sure that the tab on the shutter speed resistor mates properly with this slot on the shutter speed dial.
      Ask FixBot
    3. Pentax MX Shutter Curtains Disassembly, Remove rewind knob: step 3, image 1 of 3 Pentax MX Shutter Curtains Disassembly, Remove rewind knob: step 3, image 2 of 3 Pentax MX Shutter Curtains Disassembly, Remove rewind knob: step 3, image 3 of 3
      • Place a tool in the fork of the rewind shaft. Turn the rewind knob counterclockwise to loosen it.
      • Remove the lock ring underneath the rewind knob.
      • Remove the cover plate.
      Ask FixBot
    4. Pentax MX Shutter Curtains Disassembly, Remove top cover: step 4, image 1 of 3 Pentax MX Shutter Curtains Disassembly, Remove top cover: step 4, image 2 of 3 Pentax MX Shutter Curtains Disassembly, Remove top cover: step 4, image 3 of 3
      • Remove two M1.7 x 3.2 mm screws.
      • Remove two M1.7 x 2 mm countersunk screws.
      • Lift off top cover.
      • The release cable pin in the shutter button is loose and may fall out.
      Ask FixBot
    1. Pentax MX Shutter Curtains Disassembly, Remove front leatherette panels: step 5, image 1 of 3 Pentax MX Shutter Curtains Disassembly, Remove front leatherette panels: step 5, image 2 of 3 Pentax MX Shutter Curtains Disassembly, Remove front leatherette panels: step 5, image 3 of 3
      • Apply isopropyl alcohol to soften the leatherette adhesive.
      • Turn the self-timer lever to the charged position.
      • Peel the leatherette off the camera body, carefully working it over the self-timer lever.
      • Remove one loose cover panel.
      • Repeat for the opposite panel.
      • Installation Notes: Clean all the old adhesive off of the camera body and leatherette panels before reapplying. Use contact cement to attach.
      Ask FixBot
    2. Pentax MX Shutter Curtains Disassembly, Unsolder aperture resistor: step 6, image 1 of 1
      • Unsolder two yellow wires for the aperture resistor.
      Ask FixBot
    3. Pentax MX Shutter Curtains Disassembly, Remove front board: step 7, image 1 of 3 Pentax MX Shutter Curtains Disassembly, Remove front board: step 7, image 2 of 3 Pentax MX Shutter Curtains Disassembly, Remove front board: step 7, image 3 of 3
      • Remove four M1.9 x 3.9 mm screws.
      • Lift off front board.
      • Look for shim washers at the screw locations and note their positions.
      Ask FixBot
    1. Pentax MX Shutter Curtains Disassembly, Remove bottom cover: step 8, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove bottom cover: step 8, image 2 of 2
      • Remove three M1.7 x 2.0 mm countersunk screws.
      • Lift off bottom cover.
      • Remove loose plastic housing for motor drive contacts.
      Ask FixBot
    1. Pentax MX Shutter Curtains Disassembly, Remove light baffle: step 9, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove light baffle: step 9, image 2 of 2
      • Remove four M1.9 x 3.8 mm screws.
      • Lift off light baffle.
      • Use isopropyl alcohol to soften adhesive and detach wires from the backside of the baffle.
      Ask FixBot
    2. Pentax MX Shutter Curtains Disassembly, Unsolder shutter speed resistor: step 10, image 1 of 1
      • Unsolder two brown wires for the shutter speed resistor.
      Ask FixBot
    3. Pentax MX Shutter Curtains Disassembly, Unsolder flash sync connections: step 11, image 1 of 1
      • Unsolder one gray for the x-sync.
      • Unsolder one white wire for the FP sync.
      Ask FixBot
    4. Pentax MX Shutter Curtains Disassembly, Unsolder motor drive connections: step 12, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Unsolder motor drive connections: step 12, image 2 of 2
      • Unsolder one green wire for the motor drive connection.
      • Unsolder one blue wire for the LED switch.
      • Unsolder one red wire and one black wire.
      Ask FixBot
    5. Pentax MX Shutter Curtains Disassembly, Detach wire routing: step 13, image 1 of 1
      • Open up wire routing guides and remove all wires from them.
      • Pull the black and red wires out of the hole in the bottom of the chassis.
      • Make sure the gray wire is free and can pull away with the mirror box.
      Ask FixBot
    6. Pentax MX Shutter Curtains Disassembly, Detach viewfinder LED PCB: step 14, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Detach viewfinder LED PCB: step 14, image 2 of 2
      • Remove one M1.4 x 2.8 mm screw and washer.
      • Remove one M1.7 x 2.8 mm screw.
      • Pull the LED PCB out of the side of the mirror box.
      • Installation Notes: Install batteries and check the position of the LEDs. Position the PCB as needed then tighten the screws to fix it in place.
      Ask FixBot
    7. Pentax MX Shutter Curtains Disassembly, Disengage speed indicator idler gear: step 15, image 1 of 1
      • Loosen the slotted post but do not remove.
      • Slide the idler gear back so that it no longer engages with the speed indicator disc.
      • Installation Notes: See the process for adjusting the viewfinder speed indication after reassembly.
      Ask FixBot
    8. Pentax MX Shutter Curtains Disassembly, Remove mirror box: step 16, image 1 of 3 Pentax MX Shutter Curtains Disassembly, Remove mirror box: step 16, image 2 of 3 Pentax MX Shutter Curtains Disassembly, Remove mirror box: step 16, image 3 of 3
      • Remove two M1.7 x 4.6 mm screws.
      • Remove two slotted posts.
      • It is possible to remove the mirror box without removing the posts, since the holes can slip over the top, but the process will be easier without them in place.
      • Lift the mirror box up and tilt the top forward to remove it.
      Ask FixBot
      • It can be helpful to fire the shutter without the mirror box installed in order to troubleshoot certain issues.
      • Temporarily install the wind lever and the shutter speed dial.
      • Wind the camera.
      • Press the shutter release button.
      • Release the opening curtain latch. This is usually done by the mirror box but has to be done manually in this case.
      Ask FixBot
    1. Pentax MX Shutter Curtains Disassembly, Remove frame counter assembly: step 18, image 1 of 3 Pentax MX Shutter Curtains Disassembly, Remove frame counter assembly: step 18, image 2 of 3 Pentax MX Shutter Curtains Disassembly, Remove frame counter assembly: step 18, image 3 of 3
      • Temporarily replace the wind lever and move it into the stowed position.
      • Remove one M1.7 x 2.4 mm countersunk screw.
      • Remove one M1.7 x 3.8 mm screw.
      • Remove one M1.4 slotted nut.
      • Lift off frame counter mechanism.
      Ask FixBot
    2. Pentax MX Shutter Curtains Disassembly, Installation Notes: Frame Count Assembly: step 19, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Installation Notes: Frame Count Assembly: step 19, image 2 of 2
      • Align the post on the ratcheting gear with the slot in the top wind gear.
      • The frame counter gears will also need to mesh when installed.
      • Check the placement of this spring. It often comes loose.
      Ask FixBot
    1. Pentax MX Shutter Curtains Disassembly, Remove shutter speed resistor: step 20, image 1 of 1
      • Remove two screws.
      • Lift off shutter speed resistor.
      Ask FixBot
    2. Pentax MX Shutter Curtains Disassembly, Remove speed indicator cable mount: step 21, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove speed indicator cable mount: step 21, image 2 of 2
      • Lift off support plate. It is still connected to the shutter speed dial by a thin cable.
      • Remove two shim washers.
      • Remove the door latch spring arm.
      • Installation Notes: Route the cable through the pulleys as shown before installing the support plate.
      Ask FixBot
    3. Pentax MX Shutter Curtains Disassembly, Remove shutter dial assembly: step 22, image 1 of 3 Pentax MX Shutter Curtains Disassembly, Remove shutter dial assembly: step 22, image 2 of 3 Pentax MX Shutter Curtains Disassembly, Remove shutter dial assembly: step 22, image 3 of 3
      • Remove three screws.
      • Remove speed selector plate
      • Lift off high speed cam.
      • Remove spacer washer.
      Ask FixBot
    4. Pentax MX Shutter Curtains Disassembly, Installation Notes: Shutter Dial Assembly: step 23, image 1 of 3 Pentax MX Shutter Curtains Disassembly, Installation Notes: Shutter Dial Assembly: step 23, image 2 of 3 Pentax MX Shutter Curtains Disassembly, Installation Notes: Shutter Dial Assembly: step 23, image 3 of 3
      • Clean the high speed cam and the seat that it operates in. Apply shutter oil to the shaft and hole.
      • Set the speed selector to the '1000' position.
      • The cam for the slow speed governor should be in this position to sync properly with the speed selector.
      • Ensure that the shaft to the slow speed governor couples properly.
      Ask FixBot
    5. Pentax MX Shutter Curtains Disassembly, Remove shutter release arm: step 24, image 1 of 1
      • Mark the vertical position of the shutter release arm on the release shaft.
      • Remove two M1.4 x 2.4 mm screws.
      • Remove shutter release arm.
      Ask FixBot
    6. Pentax MX Shutter Curtains Disassembly, Remove shutter release shaft: step 25, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove shutter release shaft: step 25, image 2 of 2
      • Remove one M1.4 x 2.4 mm screw.
      • Remove the shutter release plate.
      • Slide the shutter release shaft out from the bottom of the camera.
      • Keep track of the coil spring as it slides off.
      Ask FixBot
    7. Pentax MX Shutter Curtains Disassembly, Remove closing curtain latch: step 26, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove closing curtain latch: step 26, image 2 of 2
      • Push the latch out from between the wind gears and slide it off the shaft.
      • Installation Notes: Note the position of the bias springs during installation.
      Ask FixBot
    8. Pentax MX Shutter Curtains Disassembly, Remove upper transport gear: step 27, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove upper transport gear: step 27, image 2 of 2
      • Remove one slotted post.
      • Remove plate.
      • Remove upper transport gear latch.
      • Remove upper transport gear.
      Ask FixBot
    9. Pentax MX Shutter Curtains Disassembly, Installation Notes: Upper Transport Gear: step 28, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Installation Notes: Upper Transport Gear: step 28, image 2 of 2
      • Shutter curtains should be in the wound state...
      • And the lower transport gear latch engaged.
      • Place the upper transport gear such that the right side of the slot is as close to the transport latch as possible without touching or rubbing.
      Ask FixBot
    10. Pentax MX Shutter Curtains Disassembly, Remove lower transport gear latch: step 29, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove lower transport gear latch: step 29, image 2 of 2
      • Unhook bias spring.
      • Remove one M1.4 x 2.8 mm shoulder screw.
      • Remove lower transport gear latch and bias spring.
      • Remove washer.
      Ask FixBot
    11. Pentax MX Shutter Curtains Disassembly, Remove lower transport gear: step 30, image 1 of 1
      • Lift off lower transport gear.
      • Installation Notes: Clean the upper and lower transport gears and the mounting post with isopropyl alcohol. Do not lubricate.
      Ask FixBot
    12. Pentax MX Shutter Curtains Disassembly, Remove reverse stop: step 31, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove reverse stop: step 31, image 2 of 2
      • Remove washer.
      • Remove bias spring.
      Ask FixBot
    13. Pentax MX Shutter Curtains Disassembly, Lubricate shutter: step 32, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Lubricate shutter: step 32, image 2 of 2
      • Pentax recommends using shutter oil to lubricate areas of the shutter that move rapidly during an exposure. Most of the critical areas can be accessed at this point in the disassembly. Apply the oil sparingly, just enough to coat the bearing surfaces.
      • Lubricate the pinion shafts. On the wind side, the pinions turn in their end pivots. The oil should be between the shafts and the end plates.
      • Lubricate the rollers. On the rewind side, the rollers turn on the fixed shafts. The oil should be between the rollers and the shafts.
      • If the curtain travel times are severely degraded, additional disassembly and cleaning may be necessary before lubrication is applied.
      Ask FixBot
    1. Pentax MX Shutter Curtains Disassembly, Remove tripod mount: step 33, image 1 of 1
      • Remove two countersunk screws.
      • Remove tripod mount.
      Ask FixBot
    2. Pentax MX Shutter Curtains Disassembly, Remove battery holder: step 34, image 1 of 1
      • Pull the battery compartment towards the bottom of the camera.
      • Note the routing of the red wire.
      Ask FixBot
    3. Pentax MX Shutter Curtains Disassembly, Disconnect motor drive wiring: step 35, image 1 of 1
      • Unsolder two blue wires for the shutter button switch.
      • Unsolder one green wire.
      • Pull the wires out through the hole in the chassis so they are free.
      Ask FixBot
    4. Pentax MX Shutter Curtains Disassembly, Detach the flash sync PCB: step 36, image 1 of 1
      • Remove one screw.
      • Lift away the flash sync PCB. It is still connected by the red wires.
      Ask FixBot
    5. Pentax MX Shutter Curtains Disassembly, Remove X flash sync contact: step 37, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove X flash sync contact: step 37, image 2 of 2
      • Use isopropyl alcohol to soften the adhesive holding the wires.
      • Remove the X sync contact.
      • Installation Notes: The contact should be open when the shutter is wound and should close when the opening curtain reaches the end of its travel across the frame.
      Ask FixBot
    6. Pentax MX Shutter Curtains Disassembly, Remove main meter switch: step 38, image 1 of 1
      • Lift off the main meter switch and gently pull the blue wires through the hole in the chassis.
      Ask FixBot
    7. Pentax MX Shutter Curtains Disassembly, Remove slow speed coupling rod: step 39, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove slow speed coupling rod: step 39, image 2 of 2
      • Remove one circlip.
      • Remove the slow speed coupling rod through the bottom of the chassis.
      • To get the cam stack past the governor plate, first release the shutter. Then rotate the governor plate counter-clockwise. That should provide enough clearance to remove the slow speed coupling rod.
      Ask FixBot
    8. Pentax MX Shutter Curtains Disassembly, Remove loose washers: step 40, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove loose washers: step 40, image 2 of 2
      • Remove one bushing.
      • Remove one shim washer.
      Ask FixBot
    9. Pentax MX Shutter Curtains Disassembly, Remove closing curtain delay gear: step 41, image 1 of 1
      • Remove one screw.
      • Lift off closing curtain delay gear.
      Ask FixBot
    10. Pentax MX Shutter Curtains Disassembly, Installation Notes: Closing Curtain Delay Gear: step 42, image 1 of 3 Pentax MX Shutter Curtains Disassembly, Installation Notes: Closing Curtain Delay Gear: step 42, image 2 of 3 Pentax MX Shutter Curtains Disassembly, Installation Notes: Closing Curtain Delay Gear: step 42, image 3 of 3
      • Clean the gear shaft and lubricate with shutter oil.
      • Charge the shutter. Manually push the opening curtain latch forward once the shutter is wound to hold it in position.
      • Temporarily install the slow speed governor.
      • Install the closing curtain delay gear such that the gap between the two governor plates is parallel.
      • Remove the slow speed governor.
      • Check that the stud on the bottom of the gear properly actuates the mirror release lever when the shutter is fired.
      Ask FixBot
    11. Pentax MX Shutter Curtains Disassembly, Remove closing curtain pinion gear: step 43, image 1 of 1
      • Remove one slotted screw.
      • Lift off closing curtain pinion gear.
      Ask FixBot
    12. Pentax MX Shutter Curtains Disassembly, Remove shutter curtain baffle: step 44, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove shutter curtain baffle: step 44, image 2 of 2
      • Remove shutter curtain baffle.
      Ask FixBot
    13. Pentax MX Shutter Curtains Disassembly, Remove curtain bounce stopper: step 45, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove curtain bounce stopper: step 45, image 2 of 2
      • Remove stopper spring.
      • Remove washer.
      • Measure the distance that the stopper adjustment extends from the rear wall and record the value for reference during reassembly.
      • Remove the slotted stopper adjustment screw.
      Ask FixBot
    14. Pentax MX Shutter Curtains Disassembly, Remove indicator cable pulley: step 46, image 1 of 1
      • Remove one screw.
      • Remove indicator cable pulley.
      Ask FixBot
    15. Pentax MX Shutter Curtains Disassembly, Remove curtain travel stop: step 47, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove curtain travel stop: step 47, image 2 of 2
      • Remove oil wick and retainer plate.
      • Remove retaining post using a spanner wrench.
      • Remove curtain travel stop.
      Ask FixBot
    16. Pentax MX Shutter Curtains Disassembly, Let down tension in curtain rollers: step 48, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Let down tension in curtain rollers: step 48, image 2 of 2
      • Use isopropyl alcohol to soften the screw locker on two set screws.
      • Loosen the set screws.
      • Loosen the tension adjustment until the rollers no longer pull the curtains.
      • Hold the roller shaft gear in place and unscrew the adjustment worm gear to remove it.
      Ask FixBot
    17. Pentax MX Shutter Curtains Disassembly, Remove indicator cable adjustment plate: step 49, image 1 of 3 Pentax MX Shutter Curtains Disassembly, Remove indicator cable adjustment plate: step 49, image 2 of 3 Pentax MX Shutter Curtains Disassembly, Remove indicator cable adjustment plate: step 49, image 3 of 3
      • Remove indicator cable adjustment plate.
      • Remove one curtain string pulley.
      • Installation Notes: The ends of the roller shafts sit in two holes in the indicator cable adjustment plate. Make sure those are properly seated before screwing down the plate.
      Ask FixBot
    18. Pentax MX Shutter Curtains Disassembly, Remove curtain rollers: step 50, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove curtain rollers: step 50, image 2 of 2
      • Use a slotted screw driver to hold the roller shaft in place.
      • Use a second slotted screwdriver to remove the roller shaft gears. They are reverse threaded.
      • Remove the curtain rollers.
      Ask FixBot
    19. Pentax MX Shutter Curtains Disassembly, Remove wind gear plate: step 51, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove wind gear plate: step 51, image 2 of 2
      • Remove three slotted posts.
      • Lift the wind gear plate upward and out of the chassis.
      • The curtains and curtain pinions are attached to the plate and will come away with it.
      Ask FixBot
    20. Pentax MX Shutter Curtains Disassembly, Installation Notes: Shutter Assembly: step 52, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Installation Notes: Shutter Assembly: step 52, image 2 of 2
      • Note the position of the curtains. The closing curtain (left) should sit in front of the opening curtain (right).
      • Note the routing of the curtain strings. The opening curtain strings should run behind the plastic rollers.
      • The upper string is kept in place by a metal tab that covers the roller.
      • Install the wind gear plate first, making sure that the curtain strings are properly routed as it is put in place.
      • Install the roller shafts second.
      Ask FixBot
    1. Pentax MX Shutter Curtains Disassembly, Remove X flash sync lever: step 53, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove X flash sync lever: step 53, image 2 of 2
      • Remove X flash sync lever.
      • Note the position of the bias spring for reassembly.
      Ask FixBot
    2. Pentax MX Shutter Curtains Disassembly, Remove opening curtain latch: step 54, image 1 of 1
      • Remove one screw.
      • Remove opening curtain latch.
      Ask FixBot
    3. Pentax MX Shutter Curtains Disassembly, Remove opening curtain wind gear: step 55, image 1 of 1
      • Position the wind gear so the stop is pointing rearward in camera, approximating the released state.
      • Mark the relative position of the wind gear to the pinion gear.
      • Remove one slotted screw. It is reverse threaded.
      • Remove the opening curtain wind gear. The tolerances on the shaft are very tight and it may be difficult to remove.
      • Look for a shim washer between the top and bottom wind gears.
      Ask FixBot
    4. Pentax MX Shutter Curtains Disassembly, Remove the closing curtain wind gear: step 56, image 1 of 1
      • Lift off the closing curtain wind gear.
      Ask FixBot
      • Insert wisdom here.
      Ask FixBot
    5. Pentax MX Shutter Curtains Disassembly, Remove opening curtain pinion shaft: step 58, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Remove opening curtain pinion shaft: step 58, image 2 of 2
      • Remove to slotted grub screws. Work carefully as they are easily stripped.
      • Slide the bobbins off the bottom of the shaft.
      • Remove one circlip and shim washer.
      • Pull the opening curtain pinion shaft out of the wind gear plate.
      Ask FixBot
    6. Pentax MX Shutter Curtains Disassembly, Remove closing curtain pinion shaft: step 59, image 1 of 3 Pentax MX Shutter Curtains Disassembly, Remove closing curtain pinion shaft: step 59, image 2 of 3 Pentax MX Shutter Curtains Disassembly, Remove closing curtain pinion shaft: step 59, image 3 of 3
      • Remove the plastic roller.
      • Remove one slotted grub screw. Work carefully as it is easily stripped.
      • Slide the closing curtain off the shaft.
      • Slide the closing curtain pinion shaft out of the wind gear plate.
      Ask FixBot
    7. Pentax MX Shutter Curtains Disassembly, Curtain component stacks: step 60, image 1 of 2 Pentax MX Shutter Curtains Disassembly, Curtain component stacks: step 60, image 2 of 2
      • The shim washers may have different thicknesses. Make sure to note where each one goes for reassembly.
      Ask FixBot
Sam Gustafson
14,868 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 41
Past 30 Days: 149
All Time: 331
