Community-Contributed Guide
Introduction
Go to step 1 ↓The self-timer lever does not need to be removed before disassembling the camera. If the action has become stiff or rough feeling, disassembling and cleaning the lever mechanism can restore proper functionality.
Tools
Remove the lever cap. The cap is reverse threaded.
Lift off the advance lever.
Remove the collar beneath the lever.
Set the ISO to 100 and the shutter speed to 1000.
Remove one pin head screw.
Lift off shutter speed dial.
Remove the collar beneath the dial.
Installation Notes: Make sure that the tab on the shutter speed resistor mates properly with this slot on the shutter speed dial.
Place a tool in the fork of the rewind shaft. Turn the rewind knob counterclockwise to loosen it.
Remove the lock ring underneath the rewind knob.
Remove the cover plate.
Remove two M1.7 x 3.2 mm screws.
Remove two M1.7 x 2 mm countersunk screws.
Lift off top cover.
The release cable pin in the shutter button is loose and may fall out.
Apply isopropyl alcohol to soften the leatherette adhesive.
Turn the self-timer lever to the charged position.
Peel the leatherette off the camera body, carefully working it over the self-timer lever.
Remove one loose cover panel.
Repeat for the opposite panel.
Remove four M1.9 x 3.9 mm screws.
Lift off front board.
Look for shim washers at the screw locations and note their positions.
Flood the cap with isopropyl alcohol. Some will seep underneath and soften the adhesive.
Work the cap loose with a soft tool, either wood or plastic. Metal tools will leave marks.
If the cap will not come loose, use contact adhesive to attach a tool to the face of the cap. The extra leverage will help to remove it. The contact adhesive can be removed later.
Remove one M1.7 x 3.8 mm screw.
Lift off the self-timer lever.
Remove the lever shaft from the backside.
Remove the bias spring.
Remove three M1.4 x 2.8 mm countersunk screws.
Remove the aperture preview linkage.
Remove the self-timer lever mounting plate.
Clean all parts as necessary.
