Pentax MX Mirror Box Removal
View statistics:
Past 24 Hours:
6
Past 7 Days:
24
Past 30 Days:
115
All Time:
436
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Removing the mirror box is often necessary to troubleshoot issues and access mechanisms for cleaning. The mechanisms on the side and bottom of the mirror box are common sources of a jammed camera.
    1. Pentax MX Mirror Box Removal, Remove film advance lever: step 1, image 1 of 3 Pentax MX Mirror Box Removal, Remove film advance lever: step 1, image 2 of 3 Pentax MX Mirror Box Removal, Remove film advance lever: step 1, image 3 of 3
      • Remove the lever cap. The cap is reverse threaded.
      • Lift off the advance lever.
      • Remove the collar beneath the lever.
      Ask FixBot
    2. Pentax MX Mirror Box Removal, Remove shutter speed dial: step 2, image 1 of 2 Pentax MX Mirror Box Removal, Remove shutter speed dial: step 2, image 2 of 2
      • Set the ISO to 100 and the shutter speed to 1000.
      • Remove one pin head screw.
      • Lift off shutter speed dial.
      • Remove the collar beneath the dial.
      • Installation Notes: Make sure that the tab on the shutter speed resistor mates properly with this slot on the shutter speed dial.
      Ask FixBot
    3. Pentax MX Mirror Box Removal, Remove rewind knob: step 3, image 1 of 3 Pentax MX Mirror Box Removal, Remove rewind knob: step 3, image 2 of 3 Pentax MX Mirror Box Removal, Remove rewind knob: step 3, image 3 of 3
      • Place a tool in the fork of the rewind shaft. Turn the rewind knob counterclockwise to loosen it.
      • Remove the lock ring underneath the rewind knob.
      • Remove the cover plate.
      Ask FixBot
    4. Pentax MX Mirror Box Removal, Remove top cover: step 4, image 1 of 3 Pentax MX Mirror Box Removal, Remove top cover: step 4, image 2 of 3 Pentax MX Mirror Box Removal, Remove top cover: step 4, image 3 of 3
      • Remove two M1.7 x 3.2 mm screws.
      • Remove two M1.7 x 2 mm countersunk screws.
      • Lift off top cover.
      • The release cable pin in the shutter button is loose and may fall out.
      Ask FixBot
    1. Pentax MX Mirror Box Removal, Remove front leatherette panels: step 5, image 1 of 3 Pentax MX Mirror Box Removal, Remove front leatherette panels: step 5, image 2 of 3 Pentax MX Mirror Box Removal, Remove front leatherette panels: step 5, image 3 of 3
      • Apply isopropyl alcohol to soften the leatherette adhesive.
      • Turn the self-timer lever to the charged position.
      • Peel the leatherette off the camera body, carefully working it over the self-timer lever.
      • Remove one loose cover panel.
      • Repeat for the opposite panel.
      • Installation Notes: Clean all the old adhesive off of the camera body and leatherette panels before reapplying. Use contact cement to attach.
      Ask FixBot
    2. Pentax MX Mirror Box Removal, Unsolder aperture resistor: step 6, image 1 of 1
      • Unsolder two yellow wires for the aperture resistor.
      Ask FixBot
    3. Pentax MX Mirror Box Removal, Remove front board: step 7, image 1 of 3 Pentax MX Mirror Box Removal, Remove front board: step 7, image 2 of 3 Pentax MX Mirror Box Removal, Remove front board: step 7, image 3 of 3
      • Remove four M1.9 x 3.9 mm screws.
      • Lift off front board.
      • Look for shim washers at the screw locations and note their positions.
      Ask FixBot
    1. Pentax MX Mirror Box Removal, Remove bottom cover: step 8, image 1 of 2 Pentax MX Mirror Box Removal, Remove bottom cover: step 8, image 2 of 2
      • Remove three M1.7 x 2.0 mm countersunk screws.
      • Lift off bottom cover.
      • Remove loose plastic housing for motor drive contacts.
      Ask FixBot
    1. Pentax MX Mirror Box Removal, Remove light baffle: step 9, image 1 of 2 Pentax MX Mirror Box Removal, Remove light baffle: step 9, image 2 of 2
      • Remove four M1.9 x 3.8 mm screws.
      • Lift off light baffle.
      • Use isopropyl alcohol to soften adhesive and detach wires from the backside of the baffle.
      Ask FixBot
    2. Pentax MX Mirror Box Removal, Unsolder shutter speed resistor: step 10, image 1 of 1
      • Unsolder two brown wires for the shutter speed resistor.
      Ask FixBot
    3. Pentax MX Mirror Box Removal, Unsolder flash sync connections: step 11, image 1 of 1
      • Unsolder one gray for the x-sync.
      • Unsolder one white wire for the FP sync.
      Ask FixBot
    4. Pentax MX Mirror Box Removal, Unsolder motor drive connections: step 12, image 1 of 2 Pentax MX Mirror Box Removal, Unsolder motor drive connections: step 12, image 2 of 2
      • Unsolder one green wire for the motor drive connection.
      • Unsolder one blue wire for the LED switch.
      • Unsolder one red wire and one black wire.
      Ask FixBot
    5. Pentax MX Mirror Box Removal, Detach wire routing: step 13, image 1 of 1
      • Open up wire routing guides and remove all wires from them.
      • Pull the black and red wires out of the hole in the bottom of the chassis.
      • Make sure the gray wire is free and can pull away with the mirror box.
      Ask FixBot
    6. Pentax MX Mirror Box Removal, Detach viewfinder LED PCB: step 14, image 1 of 2 Pentax MX Mirror Box Removal, Detach viewfinder LED PCB: step 14, image 2 of 2
      • Remove one M1.4 x 2.8 mm screw and washer.
      • Remove one M1.7 x 2.8 mm screw.
      • Pull the LED PCB out of the side of the mirror box.
      • Installation Notes: Install batteries and check the position of the LEDs. Position the PCB as needed then tighten the screws to fix it in place.
      Ask FixBot
    7. Pentax MX Mirror Box Removal, Disengage speed indicator idler gear: step 15, image 1 of 1
      • Loosen the slotted post but do not remove.
      • Slide the idler gear back so that it no longer engages with the speed indicator disc.
      • Installation Notes: See the process for adjusting the viewfinder speed indication after reassembly.
      Ask FixBot
    8. Pentax MX Mirror Box Removal, Remove mirror box: step 16, image 1 of 3 Pentax MX Mirror Box Removal, Remove mirror box: step 16, image 2 of 3 Pentax MX Mirror Box Removal, Remove mirror box: step 16, image 3 of 3
      • Remove two M1.7 x 4.6 mm screws.
      • Remove two slotted posts.
      • It is possible to remove the mirror box without removing the posts, since the holes can slip over the top, but the process will be easier without them in place.
      • Lift the mirror box up and tilt the top forward to remove it.
      Ask FixBot
      • It can be helpful to fire the shutter without the mirror box installed in order to troubleshoot certain issues.
      • Temporarily install the wind lever and the shutter speed dial.
      • Wind the camera.
      • Press the shutter release button.
      • Release the opening curtain latch. This is usually done by the mirror box but has to be done manually in this case.
      Ask FixBot
Sam Gustafson
14,868 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 24
Past 30 Days: 115
All Time: 436
