Pentax ME Super Top Cover Removal
    1. Pentax ME Super Top Cover Removal, Remove wind lever: step 1, image 1 of 3 Pentax ME Super Top Cover Removal, Remove wind lever: step 1, image 2 of 3 Pentax ME Super Top Cover Removal, Remove wind lever: step 1, image 3 of 3
      • Wrap a piece of masking tape around your thumb, sticky side out.
      • Turn the wind lever cap clockwise to remove (it is reverse threaded).
      • Remove the wind lever lock ring (it is also reverse threaded).
      • Remove the brass spring washer.
      • A pair of fine tipped pliers or nippers can be used in place of a spanner wrench. Be careful!
      Ask FixBot
    2. Pentax ME Super Top Cover Removal, Remove rewind lever: step 2, image 1 of 3 Pentax ME Super Top Cover Removal, Remove rewind lever: step 2, image 2 of 3 Pentax ME Super Top Cover Removal, Remove rewind lever: step 2, image 3 of 3
      • Place a tool in the fork of the rewind spindle.
      • Unscrew the rewind lever.
      • Remove the lock ring with a spanner.
      • Lift off the ISO/Exposure Compensation dial.
      Ask FixBot
    3. Pentax ME Super Top Cover Removal, Installation Notes: ISO dial: step 3, image 1 of 1
      • Ensure that the ISO dial couples with the tab on the resistor.
      • Turn the Exposure Compensation to 1/4x then back to 4x while gently pushing down. This will help the dial engage with the detent mechanism properly.
      Ask FixBot
    4. Pentax ME Super Top Cover Removal, Unscrew top cover: step 4, image 1 of 3 Pentax ME Super Top Cover Removal, Unscrew top cover: step 4, image 2 of 3 Pentax ME Super Top Cover Removal, Unscrew top cover: step 4, image 3 of 3
      • Remove two 3.3 mm #00 screws.
      • Remove one 3.2 mm #00 screw.
      • Remove one 2.6 mm #00 screw.
      Ask FixBot
    5. Pentax ME Super Top Cover Removal, Unscrew top cover: step 5, image 1 of 2 Pentax ME Super Top Cover Removal, Unscrew top cover: step 5, image 2 of 2
      • Remove two 4.3 mm #00 screws.
      Ask FixBot
    6. Pentax ME Super Top Cover Removal: step 6, image 1 of 2 Pentax ME Super Top Cover Removal: step 6, image 2 of 2
      • Lift off the top cover. The silver trim piece is loose and may fall away.
      • Remove loose washer.
      Ask FixBot
    7. Pentax ME Super Top Cover Removal, Installation Notes: Top Cover: step 7, image 1 of 1
      • The shutter pin is loose. Make sure it is in place before installing the top cover.
      • The mode dial pin must be properly coupled with the mechanisms in the camera for it to work.
      • Set the mode dial to 'M'. Place the top cover on the camera. Move the mode dial to 'B' then back to 'M' while gently pushing down.
      • The mode dial should click into place and work properly.
      Ask FixBot
Sam Gustafson
14,484 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 37
Past 30 Days: 139
All Time: 2,480
