Pentax LX Top Cover (Wind Side) Removal
  1. Pentax LX Top Cover (Wind Side) Removal, Remove winding lever: step 1, image 1 of 3 Pentax LX Top Cover (Wind Side) Removal, Remove winding lever: step 1, image 2 of 3 Pentax LX Top Cover (Wind Side) Removal, Remove winding lever: step 1, image 3 of 3
    • Winding lever cover is reverse threaded.
    • Use a piece of tape wrapped sticky side out to grip the winding lever cover. Turn clockwise to loosen and remove
    • Remove four #000 2.5 mm screws.
    • Use spanners to remove top cover retaining nut.
    Ask FixBot
  2. Pentax LX Top Cover (Wind Side) Removal, Remove shutter speed dial: step 2, image 1 of 3 Pentax LX Top Cover (Wind Side) Removal, Remove shutter speed dial: step 2, image 2 of 3 Pentax LX Top Cover (Wind Side) Removal, Remove shutter speed dial: step 2, image 3 of 3
    • Gently remove the rubber covering around the shutter speed dial.
    • Remove three #000 1.6 mm screws.
    • Remove cover ring.
    • Installation Notes: After the camera has been fully tested, use a few dabs of contact cement to fix the rubber covering back in place.
    Ask FixBot
  3. Pentax LX Top Cover (Wind Side) Removal, Remove wind side top cover: step 3, image 1 of 3 Pentax LX Top Cover (Wind Side) Removal, Remove wind side top cover: step 3, image 2 of 3 Pentax LX Top Cover (Wind Side) Removal, Remove wind side top cover: step 3, image 3 of 3
    • Remove one #00 2.5 mm screw.
    • Remove one #00 X mm screw.
    • Lift off top cover.
    Ask FixBot
Sam Gustafson
11,000 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 40
All Time: 652
