Community-Contributed Guide
Introduction
Go to step 1 ↓Any disassembly of the LX body will compromise the weather sealing. New seals must be reapplied during final reassembly to restore weather proofing.
Tools
Place a thin tool in the rewind fork and unscrew the topside knob.
Remove the washer under the rewind knob.
Remove three #000 5.5 mm screws.
Remove exposure compensation dial assembly.
Remove washer.
Remove rubber seal.
Use a piece of tape wrapped sticky side out to grip the winding lever cover. Turn clockwise to loosen and remove
Remove four #000 2.5 mm screws.
Use spanners to remove top cover retaining nut.
Gently remove the rubber covering around the shutter speed dial.
Remove three #000 1.6 mm screws.
Remove cover ring.
Remove one #00 2.5 mm screw.
Remove one #00 X mm screw.
Lift off top cover.
Remove the rubber bumper covering the screw.
Remove one #00 1.8 mm screw.
Repeat on the other side of the bottom plate (#00 3.0 mm screw).
Use isopropyl alcohol to soften the adhesive along the edge of the leatherette.
Use a dull spudger or scraper to peel off the covering.
Turn the self timer lever to the 9 o'clock position.
Loosen the entire right side leatherette in the same manner, then work it over and around the self timer lever to remove.
Remove the two cover plates under the leatherette.
They may stick to the covering adhesive and come off on their own.
This small plug may also be loose.
Unsolder one gray wire.
Unsolder two yellow wires.
Unsolder one blue wire.
Unsolder one red wire.
Unscrew four #00 X mm screws.
Unsolder one white wire.
Unsolder one pink wire.
Unsolder one light green wire.
Check the mounting points for shim washers. If they are loose, note the position and remove.
Unsolder one purple wire.
Unsolder one green wire.
Unsolder two brown wires under the loop of flex cable.
Unscrew three #00 3.0 mm screws.
Remove exp/ISO resistor assembly.
Remove exp. compensation coupling cam.
There are two loose ball bearings that sit in these holes. Do not lose.
Installation Note: Push this lever back to properly seat the exposure compensation lock. Check that the flag in the viewfinder is working properly. It should not be visible when dial is set to 1x and pop into view when set to any other value.
Unsolder five black wires.
Unsolder two green wires.
Unsolder one yellow wire.
Unsolder one orange wire.
Unsolder one light brown wire.
Unsolder one light blue wire (may appear beige).
Unsolder two black wires.
Unsolder one brown wire.
Unsolder one light blue/teal wire.
Remove four #00 1.8 mm screws.
Lift out bezel with glass attached.
Turn shutter speed selector to 'Auto'.
Turn lock lever screw clockwise to loosen. Do not remove.
Push lock lever toward the needle indicator gear.
Turn lock lever screw counter-clockwise to tighten.
Remove two #00 2.8 mm screws. Remove two loose spacers underneath the PCB.
Remove two #00 2.0 mm screws.
Remove two #00 3.0 mm screws.
Remove one #00 5.0 mm screw.
Remove mirror box by lifting up then out. Pull slowly and check for snags as you remove.
Before installing the mirror box, the shutter should be wound and the mirror released into the taking position (up against the focusing screen).
After mounting the mirror box, make sure all necessary wires are available through the bottom of the camera for soldering.
Check for proper coupling of the self timer and the shutter button release.
Check that the closing curtain latch sits forward of the mirror return latch.
Check that the FP switch lever holds the magnet lever.
Select one of the mechanical shutter speeds and test the function of the mirror and shutter. The camera should be capable of a complete exposure cycle at this point.
Unsolder three flash sync connections along the top of the viewfinder.
Remove two 2.3 mm #00 screws holding the viewfinder LEDs. These will need to be properly aligned during reassembly.
Remove one 2.3 mm #00 screw.
Pull or pry off one 3.7 mm plastic retaining post.
Pull or pry off one 2.8 mm plastic retaining post.
Gently pull main PCB away from mirror box housing.
1 Guide Comment
The Pentax LX camera does not function properly with the TTL feature when paired with the AF280T flash unit. Regardless of aperture setting—from minimum to maximum—the flash fires at full power. Furthermore, the camera's exposure indicator does not blink to confirm proper exposure after the shot. I can confirm the flash unit is in good working order, as it functions perfectly when used with a Pentax Super A camera. What should I do to resolve this issue?
