Up to 20% off select tools
Pebble battery Replacement
Views: 8.6K
View statistics:
Past 24 Hours:
7
Past 7 Days:
72
Past 30 Days:
309
All Time:
8,582
Comments: 2
2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 35 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the battery of your original Pebble watch.
If your watch won't turn on, or turns on briefly when charging. It is likely a problem with the battery
You'll need a replacement battery, as well as a soldering iron to complete this repair.
    1. Pebble battery Replacement, Check watch model: step 1, image 1 of 2 Pebble battery Replacement, Check watch model: step 1, image 2 of 2
      • Some pebble watches, especially the original Kickstarter ones, do not have screws on the back. These watches are glued together, making them much more difficult to repair. the disassembly process for those watches is not covered here.
      Ask FixBot
    2. Pebble battery Replacement, Remove wristband: step 2, image 1 of 2 Pebble battery Replacement, Remove wristband: step 2, image 2 of 2
      • Take a small flathead or something similar to push the metal rod holding the wrist band in
      • Due to the Pebble classic's age, It is likely that the rubber wristband has deteriorated significantly, which can lead to brittleness and the rubber tearing.
      • The Pebble classic uses a standard 22 mm wristband, meaning that it can be replaced with any compatible band.
      Ask FixBot
    3. Pebble battery Replacement, Remove the torx screws: step 3, image 1 of 2 Pebble battery Replacement, Remove the torx screws: step 3, image 2 of 2
      • Remove the four T4 torx screws
      Ask FixBot
    4. Pebble battery Replacement: step 4, image 1 of 2 Pebble battery Replacement: step 4, image 2 of 2
      • Use an opening tool to separate the front and back of the case
      • Do not fully separate. Doing so could break the haptic component glued to the back of the watch
      Ask FixBot
    5. Pebble battery Replacement, Separate haptic component from back: step 5, image 1 of 3 Pebble battery Replacement, Separate haptic component from back: step 5, image 2 of 3 Pebble battery Replacement, Separate haptic component from back: step 5, image 3 of 3
      • There is one component glued to the back of the watch. Use a small flathead or a similar tool to pry it from the back of the watch.
      • During re-assembly, ensure the haptic component is fitted into its original position.
      Ask FixBot
    6. Pebble battery Replacement, Remove internals: step 6, image 1 of 3 Pebble battery Replacement, Remove internals: step 6, image 2 of 3 Pebble battery Replacement, Remove internals: step 6, image 3 of 3
      • The internals of the watch lie inside a plastic housing which can be disconnected from the screen. This is more difficult for some watches than others. Use a pair of tweezers that have a good grip.
      Ask FixBot
    7. Pebble battery Replacement, Remove light shield: step 7, image 1 of 3 Pebble battery Replacement, Remove light shield: step 7, image 2 of 3 Pebble battery Replacement, Remove light shield: step 7, image 3 of 3
      • Using tweezers or fingers, carefully remove the black film from the side with the white light diffuser. Set it aside to be reapplied during reassembly.
      Ask FixBot
    8. Pebble battery Replacement, Remove light diffuser: step 8, image 1 of 3 Pebble battery Replacement, Remove light diffuser: step 8, image 2 of 3 Pebble battery Replacement, Remove light diffuser: step 8, image 3 of 3
      • Using a prying tool, separate the diffuser from the casing via the small plastic hooks.
      • This can take a decent amount of force, but take it slow. excessive bending can crack the diffusion material between the two white plastic sheets.
      Ask FixBot
    9. Pebble battery Replacement, Remove battery: step 9, image 1 of 2 Pebble battery Replacement, Remove battery: step 9, image 2 of 2
      • Using scissors or a small blade, carefully cut the ribbon cable connecting the battery to the main board.
      • Take caution as to not puncture the battery. Doing so could result in an explosion or fire.
      Ask FixBot
    10. Pebble battery Replacement, Scrape off flux residue: step 10, image 1 of 1
      • Using a sharp blade, scrape the residual flux off of the solder points. This is necessary when soldering the new battery to the board.
      Ask FixBot
    11. Pebble battery Replacement, Solder the black wire: step 11, image 1 of 2 Pebble battery Replacement, Solder the black wire: step 11, image 2 of 2
      • Using soldering iron and a pair of precision tweezers, solder the black wire of your replacement battery to the contact shown in the picture. The pre-applied solder should be sufficient for this, but more can be applied if necessary.
      • Using some kind of putty makes this much easier.
      • Soldering Iron temp around 340° C should be sufficient.
      Ask FixBot
    12. Pebble battery Replacement, Solder the red wire: step 12, image 1 of 2 Pebble battery Replacement, Solder the red wire: step 12, image 2 of 2
      • Just like with step 11, use a soldering iron and a pair of precision tweezers to solder the red wire of your replacement battery to the contact shown in the picture. The pre-applied solder should be sufficient for this, but more can be applied if necessary.
      • After successfully soldering these wires, you should see the backlight light up
      Ask FixBot
    13. Pebble battery Replacement, Insert the new battery: step 13, image 1 of 2 Pebble battery Replacement, Insert the new battery: step 13, image 2 of 2
      • Now the the new battery is soldered, Insert is as shown. Other orientations are fine as well, as long as the connection points for the wire are not under stress.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take special care re-inserting the light diffuser.
3 other people completed this guide.
Author
with
Elliot Wyrick
327 Reputation
1 Guide authored
2 Guide Comments
Hard but doable.
Make sure to pull the internals out by the up/down side closest to the battery (not the vibrator) or you'll crack the mount like I did, which might lead to screen tearing.
It's so easy to crack the light diffuser, I sure did. My black film didn't want to come off, so it stayed in the watch, which was fine.
Tiny soldier points, what a YouTube if your not familiar on tiny points.
I put the internals back in about a dozen times before I had good enough contact to avoid screen tearing, and even then it only did under pressure...which I got when I screwed it back together.
In the end, success!!!
Thank you author.
Rob - Reply Share
Each time I re-installed the board in my watch, connecting it to the screen, the screen jut showed garbage (like static, or stars). I spent a lot of time troubleshooting the connector before realizing that I just needed to reboot it with back + up + select.
Joel Crane - Reply Share
Past 24 Hours: 7
Past 7 Days: 72
Past 30 Days: 309
All Time: 8,582
