Up to 20% off select tools
Pebble Time Screen Cover Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
100
All Time:
2,619
Comments: 6
1 comment on steps, 5 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Replacement guide for the screen cover of the Pebble Time.
    1. Pebble Time Screen Cover Replacement, Screen Cover: step 1, image 1 of 1
      • Lay the watch flat on your workstation.
      Ask FixBot
    2. Pebble Time Screen Cover Replacement: step 2, image 1 of 2 Pebble Time Screen Cover Replacement: step 2, image 2 of 2
      • Use the metal spudger to carefully pull apart the screen cover from the case.
      • Replace the metal spudger with a plastic opening tool to hold the cover open.
      Ask FixBot
    3. Pebble Time Screen Cover Replacement: step 3, image 1 of 1
      • Use the metal spudger tool to carefully loosen the rest of the cover.
      Ask FixBot
    4. Pebble Time Screen Cover Replacement: step 4, image 1 of 1
      • Carefully, pull apart the cover with the plastic opening tool.
      Ask FixBot
Author
with
Nicolas Hempe
1,516 Reputation
5 Guides authored
USF Tampa, Team 1-3, Sullivan Spring 2017 Member of USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
4 Members
72 Guides authored
5 Guide Comments
What does one use to hold the screen on and reseal for waterproofing?
Shannon Oswald - Reply Share
Using RTV silicon is problematic, I got some on my LCD and now I’m looking for a replacement Pebble.
HI I scratched my Crystal on my Pebble Time watch. Can the Crystal be buffed to get the scratch out??
Janice Pruett - Reply Share
This is a brand new Pebble Time watch!!
ā€œCONCLUSION
To reassemble your device, follow these instructions in reverse order.ā€
Yeah, what about an adhesive or sealant? Best practice for doing so?
Adam MacDonald - Reply Share
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 100
All Time: 2,619
