Up to 20% off select tools
Pebble Time Circuit Board Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
93
All Time:
1,549
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Replacement guide for the circuit board of the Pebble Time.
    1. Pebble Time Circuit Board Replacement, Screen Cover: step 1, image 1 of 1
      • Lay the watch flat on your workstation.
      Ask FixBot
    2. Pebble Time Circuit Board Replacement: step 2, image 1 of 2 Pebble Time Circuit Board Replacement: step 2, image 2 of 2
      • Use the metal spudger to carefully pull apart the screen cover from the case.
      • Replace the metal spudger with a plastic opening tool to hold the cover open.
      Ask FixBot
    3. Pebble Time Circuit Board Replacement: step 3, image 1 of 1
      • Use the metal spudger tool to carefully loosen the rest of the cover.
      Ask FixBot
    4. Pebble Time Circuit Board Replacement: step 4, image 1 of 1
      • Carefully, pull apart the cover with the plastic opening tool.
      Ask FixBot
    1. Pebble Time Circuit Board Replacement, Screen: step 5, image 1 of 1
      • Insert metal spudger into the side of the screen shown in the picture.
      Ask FixBot
    2. Pebble Time Circuit Board Replacement: step 6, image 1 of 1
      • Use the metal spudger to pry the screen up.
      Ask FixBot
    3. Pebble Time Circuit Board Replacement: step 7, image 1 of 3 Pebble Time Circuit Board Replacement: step 7, image 2 of 3 Pebble Time Circuit Board Replacement: step 7, image 3 of 3
      • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
      • Disconnect the screen from the circuit board.
      Ask FixBot
    1. Pebble Time Circuit Board Replacement, Circuit Board: step 8, image 1 of 1
      • Keep the watch flat on your workstation.
      Ask FixBot
    2. Pebble Time Circuit Board Replacement: step 9, image 1 of 1
      • Locate the three screws on the circuit board.
      • Remove using the J000 Philips head screwdriver.
      Ask FixBot
    3. Pebble Time Circuit Board Replacement: step 10, image 1 of 3 Pebble Time Circuit Board Replacement: step 10, image 2 of 3 Pebble Time Circuit Board Replacement: step 10, image 3 of 3
      • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
      • Move apart the connector to expose the fourth screw.
      Ask FixBot
    4. Pebble Time Circuit Board Replacement: step 11, image 1 of 1
      • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
      Ask FixBot
    5. Pebble Time Circuit Board Replacement: step 12, image 1 of 2 Pebble Time Circuit Board Replacement: step 12, image 2 of 2
      • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
      • Remove the circuit board from the case.
      Ask FixBot
Author
with
Nicolas Hempe
1,516 Reputation
5 Guides authored
USF Tampa, Team 1-3, Sullivan Spring 2017 Member of USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 93
All Time: 1,549
