Up to 20% off select tools
Pebble Time Battery Replacement
Views: 29K
View statistics:
Past 24 Hours:
7
Past 7 Days:
50
Past 30 Days:
259
All Time:
28,747
Comments: 15
3 comments on steps, 12 guide comments.
Go to guide comments
Completed: 35
35 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Removal of battery for replacement.
    1. Pebble Time Battery Replacement, Screen Cover: step 1, image 1 of 1
      • Lay the watch flat on your workstation.
      Ask FixBot
    2. Pebble Time Battery Replacement: step 2, image 1 of 2 Pebble Time Battery Replacement: step 2, image 2 of 2
      • Use the metal spudger to carefully pull apart the screen cover from the case.
      • Replace the metal spudger with a plastic opening tool to hold the cover open.
      Ask FixBot
    3. Pebble Time Battery Replacement: step 3, image 1 of 1
      • Use the metal spudger tool to carefully loosen the rest of the cover.
      Ask FixBot
    4. Pebble Time Battery Replacement: step 4, image 1 of 1
      • Carefully, pull apart the cover with the plastic opening tool.
      Ask FixBot
    1. Pebble Time Battery Replacement, Screen: step 5, image 1 of 1
      • Insert metal spudger into the side of the screen shown in the picture.
      Ask FixBot
    2. Pebble Time Battery Replacement: step 6, image 1 of 1
      • Use the metal spudger to pry the screen up.
      Ask FixBot
    3. Pebble Time Battery Replacement: step 7, image 1 of 3 Pebble Time Battery Replacement: step 7, image 2 of 3 Pebble Time Battery Replacement: step 7, image 3 of 3
      • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
      • Disconnect the screen from the circuit board.
      Ask FixBot
    1. Pebble Time Battery Replacement, Circuit Board: step 8, image 1 of 1
      • Keep the watch flat on your workstation.
      Ask FixBot
    2. Pebble Time Battery Replacement: step 9, image 1 of 1
      • Locate the three screws on the circuit board.
      • Remove using the J000 Philips head screwdriver.
      Ask FixBot
    3. Pebble Time Battery Replacement: step 10, image 1 of 3 Pebble Time Battery Replacement: step 10, image 2 of 3 Pebble Time Battery Replacement: step 10, image 3 of 3
      • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
      • Move apart the connector to expose the fourth screw.
      Ask FixBot
    4. Pebble Time Battery Replacement: step 11, image 1 of 1
      • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
      Ask FixBot
    5. Pebble Time Battery Replacement: step 12, image 1 of 2 Pebble Time Battery Replacement: step 12, image 2 of 2
      • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
      • Remove the circuit board from the case.
      Ask FixBot
    1. Pebble Time Battery Replacement, Battery: step 13, image 1 of 1
      • After removing the circuit board, the battery is located in the middle of the case.
      Ask FixBot
    2. Pebble Time Battery Replacement: step 14, image 1 of 2 Pebble Time Battery Replacement: step 14, image 2 of 2
      • Locate the battery connector on the left side of the case.
      • Carefully disconnect the wire using a metal spudger.
      Ask FixBot
    3. Pebble Time Battery Replacement: step 15, image 1 of 2 Pebble Time Battery Replacement: step 15, image 2 of 2
      • After disconnecting the battery use the plastic opening tool to lift the battery off of the case.
      • The battery might be glued to the case.
      Ask FixBot
35 other people completed this guide.
Author
with
Nicolas Hempe
1,516 Reputation
5 Guides authored
USF Tampa, Team 1-3, Sullivan Spring 2017 Member of USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
4 Members
72 Guides authored
12 Guide Comments
Where did you purchase the replacement battery?
Dimas Caparros - Reply Share
Got mine on Amazon
kwojdak - Reply Share
What is everyone using for sticky tape to hold the bezel/crystal on that will ensure the pebble is still waterproof?
Shannon Oswald - Reply Share
Attempted this using RTV Silicon, and it is %#*@ difficult to not get it EVERYWHERE! I got some on my LCD, now I’m looking for another Pebble. Just use a little superglue on the outside and don’t figure on it being waterproof anymore - I guess.
There’s a lot of replacement battery on internet. Just search “150mAh P11G7T-01-S01”.
Xie Yanbo - Reply Share
Past 24 Hours: 7
Past 7 Days: 50
Past 30 Days: 259
All Time: 28,747
