Pebble Steel Vibration Motor Replacement
    1. Pebble Steel Vibration Motor Replacement, Internal Hardware: step 1, image 1 of 3 Pebble Steel Vibration Motor Replacement, Internal Hardware: step 1, image 2 of 3 Pebble Steel Vibration Motor Replacement, Internal Hardware: step 1, image 3 of 3
      • Use a Torx T3 screwdriver to unscrew the four 3.5 mm Torx T3 screws holding the back plate.
      • Make sure the screws are kept in a safe place to insure they are not lost.
      • Remove the back plate.
      Ask FixBot
    2. Pebble Steel Vibration Motor Replacement: step 2, image 1 of 2 Pebble Steel Vibration Motor Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • The plastic frame is clipped inside the steel body with four clips, two each on the left and the right side of the watch, near the corners. You can stick a small screwdriver into the cutouts right above the clips and gently lever the plastic frame up, corner by corner.
      • Once the clips are released, use a pair of tweezers to grab onto the black plastic frame and remove the internal hardware.
      • Adhesive on the back side of the battery holds the internal components to the front case.
      • Use tweezers or a plastic opening tool to disconnect the ribbon cable from the motherboard.
      Ask FixBot
    1. Pebble Steel Vibration Motor Replacement, Vibration Motor: step 3, image 1 of 1
      • Use a small plastic opening tool to remove the vibration motor from the motherboard.
      Ask FixBot
    2. Pebble Steel Vibration Motor Replacement: step 4, image 1 of 1
      Buy
      • Use a pair of tweezers to detach both the blue and red wires from the motherboard.
      Ask FixBot
Orlandria Heggs
545 Reputation
3 Guides authored
USF Tampa, Team 1-7, Leahy Fall 2015 Member of USF Tampa, Team 1-7, Leahy Fall 2015
USFT-LEAHY-F15S1G7
3 Members
60 Guides authored
2 Guide Comments
Any idea where I can get the vibration motor ?
Armacalypse Roguewind - Reply Share
Do you think these would be ok as a replacement for my pebble (original, first gen.) http://www.ebay.it/itm/5-Motorino-Motore...
cerebro84 - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 39
All Time: 3,901
