Patchwork Repair for a Damaged Hat
    1. Patchwork Repair for a Damaged Hat, Patchwork Repair for a Damaged Hat: step 1, image 1 of 2 Patchwork Repair for a Damaged Hat, Patchwork Repair for a Damaged Hat: step 1, image 2 of 2
      • Carefully cut away any torn or damaged sections of the visor using scissors.
      • For torn fabric, use fabric scissors for a cleaner cut.
      Ask FixBot
    2. Patchwork Repair for a Damaged Hat: step 2, image 1 of 2 Patchwork Repair for a Damaged Hat: step 2, image 2 of 2
      • Use sandpaper to smooth out any rough or jagged edges around the damaged area.
      Ask FixBot
    3. Patchwork Repair for a Damaged Hat: step 3, image 1 of 2 Patchwork Repair for a Damaged Hat: step 3, image 2 of 2
      • Place the hat on a piece of cardboard and trace the shape needed to cover the damaged section of the visor.
      • After tracing the edge of the damaged visor, add extra width to the cardboard patch.
      Ask FixBot
    4. Patchwork Repair for a Damaged Hat: step 4, image 1 of 3 Patchwork Repair for a Damaged Hat: step 4, image 2 of 3 Patchwork Repair for a Damaged Hat: step 4, image 3 of 3
      • Cut out the traced shape using scissors.
      • Make a clean, straight cut through the center of the patch using an X-acto knife, so that the patch can be split open on one side.
      Ask FixBot
    5. Patchwork Repair for a Damaged Hat: step 5, image 1 of 3 Patchwork Repair for a Damaged Hat: step 5, image 2 of 3 Patchwork Repair for a Damaged Hat: step 5, image 3 of 3
      • Place superglue into the opened section of the patch.
      • Quickly align the patch with the damaged edge of the visor, with the original visor's material sandwiched between the sides of the cardboard patch.
      • Apply pressure to each side of the patch as it sandwiches the visor. Hold firmly until the glue sets.
      Ask FixBot
    6. Patchwork Repair for a Damaged Hat: step 6, image 1 of 3 Patchwork Repair for a Damaged Hat: step 6, image 2 of 3 Patchwork Repair for a Damaged Hat: step 6, image 3 of 3
      • Trim any excess material off of the patch.
      • Measure the scrap fabric to fit the patch.
      Ask FixBot
    7. Patchwork Repair for a Damaged Hat: step 7, image 1 of 3 Patchwork Repair for a Damaged Hat: step 7, image 2 of 3 Patchwork Repair for a Damaged Hat: step 7, image 3 of 3
      • Apply superglue to each side of the cardboard patch.
      • Place the scrap fabric over the patch, pressing down to secure it.
      • Apply pressure to the fabric until the glue fully dries.
      Ask FixBot
Now your hat is fully repaired! From here, you may choose to add creative elements such as embroidery or painting to the finished patch.
Thank you for using our repair guide, let us know if this technique worked for you!
2 other people completed this guide.
aisha
175 Reputation
1 Guide authored
UC Davis, Team 2-7, Whithaus Spring 2025 Member of UC Davis, Team 2-7, Whithaus Spring 2025
UCD-WHITHAUS-S25S2G7
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 16
Past 7 Days: 94
Past 30 Days: 321
All Time: 2,733
